converting a string to [GUID] RRS feed
  • Hi chaps,
    [GUID]$a = "00000000-00000000-0000-000000000000"
    doesnt work, although i didnt really expect it to...
     [Guid]::NewGuid($a) doesnt work either, but i must be close ? :)
    Friday, July 24, 2009 9:42 AM
  • You where very close ;)
    PS C:\> $guid = [GUID]"00000000-0000-0000-0000-000000000000"
    PS C:\> $guid.ToString()
    actualy you allready did it (only number count was not correct )
    PS C:\> [GUID]$a = "00000000-0000-0000-0000-000000000000"
    PS C:\> $a
    PS C:\> $a.tostring()
    Note that the default output is not string version of the GUID you need to call the tostring method for that
    Greetings /\/\o\/\/
    Friday, July 24, 2009 1:15 PM
  • I'm struggling with the concept of *converting* something to a GUID...  Why?
    Why not just create a new one?
    PS>[system.guid]::newguid()
    Friday, July 24, 2009 10:05 AM
  • I am trying to preserve the value of 'VirtualSystemIdentifiers' on some Hyper-V WMI resources when 'cloning' a VM on another host.  I want to be able to do something like this:
    $OLD_NIC = Get-WmiObject -namespace root/virtualization -query "SELECT * FROM Msvm_SyntheticEthernetPortSettingData WHERE ElementName = '$($vm) Network Adapter'"
    [GUID]$GUID = $OLD_NIC.VirtualSystemIdentifiers
    blah blah blah
    $new_nic.VirtualSystemIdentifiers = “{$GUID}”
    Friday, July 24, 2009 10:14 AM
    PS C:\> $a
    Greetings /\/\o\/\/
  • Ah, I know where I was going wrong. I'm an idiot :)
    VirtualSystemIdentifiers of Msvm_SyntheticEthernetPortSettingData gives the GUID between closed and open 'squiggly brackets', i.e { and }, I'm not sure of their correct term. If I get the value of VirtualSystemIdentifiers as a [string] and then .replace("{",""), etc etc
    It works fine.
    Thanks guys!
    Friday, July 24, 2009 1:38 PM
  • Another tip
    instead of the replace you can also use the Trim method and get both  { and } removed at the same time :
    "{4c935adb-d8a1-4e98-a837-f5f4904ab01a}".trim("{}")
    Greetings  /\/\o\/\/
    Friday, July 24, 2009 1:50 PM
