Using Microsoft Remote Desktop and Amazon Web Service Connection Problem RRS feed
  • Hello,
    I am attempting to use Microsoft Power BI on my mac and I need to connect using amazon <g class="gr_ gr_203 gr-alert gr_spell gr_inline_cards gr_disable_anim_appear ContextualSpelling" data-gr-id="203" id="203">aws</g> and Microsoft remote desktop.
    When I try to log in, I get the following:
    "The user account used to connect to ... (remote PC) did not work. try again"
    How do I remedy this issue? The password is not being accepted that I am given on <g class="gr_ gr_819 gr-alert gr_spell gr_inline_cards gr_disable_anim_appear ContextualSpelling" data-gr-id="819" id="819">aws</g> when I create my instance credentials
    Sunday, September 8, 2019 8:24 PM
  • your question:
    I am attempting to use Microsoft Power BI on my mac and I need to connect using amazon aws  and Microsoft remote desktop.
    How do I remedy this issue? The password is not being accepted that I am given on aws when I create my instance credentials .
    Best Regards
    Andy YOU
    Monday, September 9, 2019 10:50 AM
  • HI
    if you install Microsoft Remote Desktop for Mac Version 10.3.2 (1650) on your mac computer ,will the problem persist ?
    https://rink.hockeyapp.net/apps/5e0c144289a51fca2d3bfa39ce7f2b06/
    2 is there windows pc in your environment ?if you use windows pc to remote access amazon aws vm,will the problem persist ?
    3 what's the os version of vm in AWS ?
    4 if the problem persist ,we can try to contact AWS support .
    "I cannot login to my AWS Account "
    https://aws.amazon.com/contact-us/?nc1=f_m
    Best Regards
    Andy YOU
    Monday, September 9, 2019 2:13 PM
  • HI
    Is there any progress on your question?
    Best Regards
    Andy YOU
    Thursday, September 12, 2019 10:18 AM
  • HI
    Is there anything to help you?
    Best Regards
    Andy YOU
    Tuesday, September 17, 2019 2:14 AM
