Apache Mahout™ is a machine learning library built for use in scalable machine learning applications. Recommender engines are some of the most immediately recognizable machine learning applications in use today. In this tutorial you use the Million Song Dataset to create song recommendations for users based on their past listening habits.
You learn:
  • How to use Recommender Engines
This tutorial is composed of the following segments:
  1. Examining and formatting the data.
  2. Running the Mahout job.
Setup and configuration
You must have an account to access Apache™ Hadoop™-based Services for Windows Azure and have created a cluster to work through this tutorial. To obtain an account and create a Hadoop cluster, follow the instructions outlined in the Getting started with Microsoft Hadoop on Windows Azure section of the Introduction to Hadoop on Windows Azure topic.
Apache Mahout provides a built-in implementation for Item-based Collaborative Filtering. Item-based Collaborative Filtering is a popular way to conduct recommendation data mining.
This example deals with users that interact with items (songs). These users indicate preferences towards the items, expressed in the number of times they have listened to a song. You can view a sample of this dataset on the Echo Nest Taste Profile Subset web page:
Sample data from the Million Song Dataset
To use this dataset with Mahout you need to do two things:
  1. Convert the IDs of both the songs and users to integer values.
  2. Save the new values with their rankings to a comma-separated file.
Start by launching Visual Studio 2010. In Visual Studio, select File -> New Project. In the Installed Templates pane, inside the Visual C# node, select the Window category, and then select Console Application from the list. Name the project ConvertToMahoutInput.
Creating a console application
Once the application is created, open the Program.cs file and add the following static members to the Program class:
const char tab = '\u0009';
static Dictionary<string, int> usersMapping = new Dictionary<string, int>();
static Dictionary<string, int> songMapping = new Dictionary<string, int>();
Next, fill the Main method with the following code:
var inputStream = File.Open(args[0], FileMode.Open);
var reader = new StreamReader(inputStream);
var outStream = File.Open("mInput.txt", FileMode.OpenOrCreate);
var writer = new StreamWriter(outStream);
var i = 1;
var line = reader.ReadLine();
while (!string.IsNullOrWhiteSpace(line))
    i++;
    if (i > 5000)
    break;
    var outLine = line.Split(tab);
    int user = GetUser(outLine[0]);
    int song = GetSong(outLine[1]);
    writer.Write(user);
    writer.Write(',');
    writer.Write(song);
    writer.Write(',');
    writer.WriteLine(outLine[2]);
Console.WriteLine("saved {0} lines to {1}", i, args[0]);
reader.Close();
writer.Close();
SaveMapping(usersMapping, "usersMap.csv");
SaveMapping(songMapping, "songMapping.csv");
Console.WriteLine("Mapping saved");
Console.ReadKey();
Now create the GetUser and GetSong functions, which convert the ids to integers:
static int GetUser(string user)
    if (!usersMapping.ContainsKey(user))
        usersMapping.Add(user, usersMapping.Count + 1);
    return usersMapping[user];
static int GetSong(string song)
    if (!songMapping.ContainsKey(song))
        songMapping.Add(song, songMapping.Count + 1);
    return songMapping[song];
Finally, create the utility that implements the SaveMapping method that saves bot mapping dictionaries to .csv files.
static void SaveMapping(Dictionary<string, int> mapping, string fileName)
    var stream = File.Open(fileName, FileMode.Create);
    var writer = new StreamWriter(stream);
    foreach (var key in mapping.Keys)
        writer.Write(key);
        writer.Write(',');
        writer.WriteLine(mapping[key]);
    writer.Close();
Download the sample data from this link. Once downloaded, open train_triplets.txt.zip and extract train_triplets.txt.
When running the utility, include a command line argument with the location of train_triplets.txt. To do so, right-click the ConvertToMahoutInput project node in Solution Explorer and select Properties. On the project properties page, add the path of train_triplets.txt to the Command line arguments text box:
Setting the Command line argument
Press F5 to run the program. Once complete, open the bin\Debug folder from the location to which the project was saved, and view the utility's output.
The output of the ConvertToMahoutInput utility
Open the Hadoop cluster portal at https://www.hadooponazure.com/, and click the Remote Desktop icon.
The Remote Desktop icon
Zip and copy the mInput.txt file from the bin\Debug folder to c:\ on the remote cluster. Once the file is copied, extract it.
Create a file that contains the ID of the user for whom you will be generating recommendations. To do so, simply create a text file called users.txt in c:\, containing the id of a single user.
Note: You can generate recommendations for more users by putting their IDs on separate lines.
Next, upload both mInput.txt and users.txt to HDFS. To do so, open the Hadoop Command Line (on Desktop) and run the following commands:
hadoop fs -copyFromLocal c:\mInput.txt input\mInput.txt
hadoop fs -copyFromLocal c:\users.txt input\users.txt
Now we can run the Mahout job using the following command:
hadoop jar c:\Apps\dist\mahout-0.5\mahout-core-0.5-job.jar org.apache.mahout.cf.taste.hadoop.item.RecommenderJob --input=input/mInput.txt --output=output --usersFile=input/users.txt
The Mahout job should run for several minutes, after which an output file will be created. Run the following command to create a local copy of the output file:
hadoop fs -copyToLocal output/part-r-00000 c:\output.txt
Open the output.txt file from the c:\ root folder and inspect its contents. The structure of the file is as follows:
user    [song:rating,song:rating, ...]
Summary
Recommender engines provide important functionality for many modern social networking sites, online shopping, streaming media, and other internet sites. Mahout provides an out-of-the-box recommendation engine that is easy to use, contains many useful features, and is scalable on Hadoop.
