Small Basic > Getting Started Guide > Chapter 7: Fun with Shapes
Here we draw multiple rectangles in a loop, with increasing size.
GraphicsWindow.BackgroundColor = "Black"GraphicsWindow.PenColor = "LightBlue"GraphicsWindow.Width = 200GraphicsWindow.Height = 200 For i = 1 To 100 Step 5 GraphicsWindow.DrawRectangle(100 - i, 100 - i, i * 2, i * 2)EndFor
"Black"
"LightBlue"
EndFor
Figure 7.1 - Rectangalore
A variant of the previous program draws circles instead of squares.
GraphicsWindow.BackgroundColor = "Black"GraphicsWindow.PenColor = "LightGreen"GraphicsWindow.Width = 200GraphicsWindow.Height = 200 For i = 1 To 100 Step 5 GraphicsWindow.DrawEllipse(100 - i, 100 - i, i * 2, i * 2)EndFor
"LightGreen"
For
i = 1
To
100
Step
5
Figure 7.2 - Circtacular
This program uses the operation GraphicsWindow.GetRandomColor to set random colors for the brush and then uses Math.GetRandomNumber to set the x and y co-ordinates for the circles. These two operations can be combined in interesting ways to create interesting programs that give different results each time they are run.
GraphicsWindow.BackgroundColor = "Black"For i = 1 To 1000 GraphicsWindow.BrushColor = GraphicsWindow.GetRandomColor() x = Math.GetRandomNumber(640) y = Math.GetRandomNumber(480) GraphicsWindow.FillEllipse(x, y, 10, 10)EndFor
1000
Figure 7.3 - Randomize
The following program draws a simple triangle fractal using random numbers. A fractal is a geometric shape that can be subdivided into parts, each of which resembles the parent shape accurately. In this case, the program draws hundreds of triangles each of which resembles its parent triangle. And since the program runs for a few seconds, you can actually see the triangles forming slowly from mere dots. The logic itself is somewhat hard to describe and I’ll leave it as an exercise for you to explore.
GraphicsWindow.BackgroundColor = "Black"x = 100y = 100 For i = 1 To 100000 r = Math.GetRandomNumber(3) ux = 150 uy = 30 If (r = 1) then ux = 30 uy = 1000 EndIf If (r = 2) Then ux = 1000 uy = 1000 EndIf x = (x + ux) / 2 y = (y + uy) / 2 GraphicsWindow.SetPixel(x, y, "LightGreen")EndFor
x = 100
y = 100
100000
ux = 150
uy = 30
If
(r = 1) then
ux = 30
uy = 1000
EndIf
(r = 2)
Then
ux = 1000
x = (x + ux) / 2
y = (y + uy) / 2
Figure 7.4 - Triangle Fractal
If you want to really see the dots slowly forming the fractal, you can introduce a delay in the loop by using the Program.Delay operation. This operation takes in a number that specifies in milliseconds, how long to delay. Here’s the modified program, with the modified line in bold.
GraphicsWindow.BackgroundColor = "Black"x = 100y = 100 For i = 1 To 100000 r = Math.GetRandomNumber(3) ux = 150 uy = 30 If (r = 1) then ux = 30 uy = 1000 EndIf If (r = 2) Then ux = 1000 uy = 1000 EndIf x = (x + ux) / 2 y = (y + uy) / 2 GraphicsWindow.SetPixel(x, y, "LightGreen") Program.Delay(2)EndFor
Program.Delay(2)
Increasing the delay will make the program slower. Experiment with the numbers to see what’s best for your taste.
Another modification you can make to this program is to replace the following line:
with
color = GraphicsWindow.GetRandomColor()
GraphicsWindow.SetPixel(x, y, color)
This change will make the program draw the pixels of the triangle using random colors.
Next Chapter
