Data Protection Manager (DPM) in System Center 2012 and 2016 can be deployed using tape-based backup for data protected by the DPM server. A tape library or stand-alone tape drive can be connected to DPM servers. For more information see Planning the Tape Libraries Configuration. The following tables summarize tape libraries that are compatible with DPM in System Center 2012, 2012 R2, and 2016.
NOTE:  Tape libraries configured with a virtual Fibre Channel adapter are only supported when using certified tape library hardware on the following configurations:
System Center Data Protection Manager 2012 R2 U3 (or later) running on Windows 2012 R2 (or later).
System Center Data Protection Manager 2016 running on Windows Server 2012 R2 (or later).
Support Matrix
DPM 2012
DPM 2012 R2
DPM 2016
Windows Server 2012 R2      x       x
     x
Windows Server 2016      x
      x
       x
To determine if a tape library is supported by virtual Fibre Channel adapter, contact the tape library hardware vendor or run the DPM Tape Library Compatibility Test tool. For additional information about the DPM Tape Library Compatibility Test tool, see Verify tape library compatibility.
Below libraries are only certified with physical setup of Data Protection Manager 2012 R2 or Data Protection Manager 2016.
 Important
The tables below have a load of content, which exceed the Wiki page width. To see all content, you need to scroll to the right in the tables.
BDT
Library Model Name Operating System Changer Driver Version Library Firmware Revision Additional Libraries in Test Tape Drive Type Tape Driver Version Tape Drive Firmware Revision
FlexStor II 1U
5.2.3790.7,  06/06/2009, signed 2.4 2U, 4U, 8U HP LTO5 HH FC 1.0.6.3, 10/07/2010, signed Y23B
FlexStor II 1U
5.2.3790.7, 06/06/2009, signed 2.4 2U, 4U, 8U HP LTO5 HH SAS 1.0.6.3, 10/07/2010, signed Z21B
FlexStor II 4U
5.2.3790.7, 06/06/2009, signed 4.70/3.00e 2U, 8U HP LTO5  FH SAS 1.0.6.1, 05/14/2009, signed X22B
FlexStor II 4U
5.2.3790.7, 06/06/2009, signed 4.70/3.00e 2U, 8U HP LTO5 FH FC 1.0.6.3, 10/07/2010, signed I5BB
FlexStor II 4U
signed
4.70/3.00e 2U, 8U IBM LTO5 FH FC 6.2.1.5, 01/13/2011, signed A6S0
FlexStor II 4U
5.2.3790.7, 06/06/2009, signed 4.70/3.00e 2U, 8U IBM LTO5 FH SAS 6.2.1.5, 01/13/2011, signed A6S0
FlexStor II 4U
5.2.3790.7, 06/06/2009, signed 4.70/3.00e 1U, 2U, 8U IBM LTO5 HH FC 6.2.1.5, 01/13/2011, signed A6S1
FlexStor II 4U
5.2.3790.7, 06/06/2009, signed 4.70/3.00e 1U, 2U, 8U IBM LTO5 HH SAS 6.2.1.5, 01/13/2011, signed A6S1
FlexStor II 4U 2008 R2 5.2.3790.7, 06/06/2009, signed 4.90/3.20e 1U, 2U, 8U HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 22EB
FlexStor II 4U 2012 8.0.0.1, 07/05/2012,
signed
FlexStor II 4U 2008 R2 5.2.3790.7, 06/06/2009, signed 4.90/3.20e 1U, 2U, 8U HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 32CB
signed
FlexStor II 4U 2008 R2 5.2.3790.7, 06/06/2009, signed 4.90/3.20e 1U, 2U, 8U IBM LTO6 HH FC 6.2.3.3, 10/29/2012, signed CBW5
signed
FlexStor II 4U 2008 R2 5.2.3790.7, 06/06/2009, signed 4.90/3.20e 1U, 2U, 8U IBM LTO6 HH SAS 6.2.3.3, 10/29/2012, signed CBW5
signed
FlexStor II 4U 2012\2012R2
8.1.0.0, 01/07/2014,
signed
5.03/3.20e 1U,2U IBM LTO7 HH FC
6.2.5.5, 09/08/2015,
signed
FA11
8.1.0.0,01/07/2014,
signed
5.03/3.20e 1U,2U IBM LTO7 HH SAS
signed
FA11
FlexStor II 4U  2012/2012R2 8.1.0.0, 01/07/2014
signed
5.40/3.20e  1U, 2U IBM LTO8 HH FC 6.2.6.6, 10/24/2017,
signed
HB81
FlexStor II 4U  2012/2012R2 8.1.0.0, 01/07/2014,
signed
5.40/3.20e  1U, 2U IBM LTO8 HH SAS 6.2.6.6, 10/24/2017,
signed
HB81
FlexStor II 4U
2016 8.3.0.2. 07/03/2017
signed
5.40/3.20e 1U, 2U IBM LT08 HH FC  6.2.6.6, 10/24/2017
signed
HB81
FlexStor II 4U
2016 8.3.0.2, 07/03/2017
signed
HH SAS
6.2.6.6, 10/24/2017
signed
HB81
MultiStor  2012/2012R2 8.1.0.0, 01/07/2014
signed
 1.1.0-0012
IBM LTO6 HH FC
signed
H991
MultiStor  2012/2012R2 8.1.0.0,  01/07/2014,
signed
 1.1.0-0012   IBM LT06 HH SAS 6.2.6.6, 10/24/2017,
signed
H991
signed
 1.1.0-0012   IBM LT07 HH FC
signed
HB81
signed
 1.1.0-0012   IBM LT07 HH SAS 6.2.6.6,  10/24/2017,
signed
HB81
signed
 1.1.0-0012   IBM LT08 HH FC  6.2.6.6, 10/24/2017,
signed
HB81
signed
 1.1.0-0012   IBM LT08 HH SAS 6.2.6.6, 10/24/2017
signed
HB81
MultiStor  2016 8.3.0.2,  07/03/2017
signed
 1.1.0-0012   IBM LT06 HH FC 6.2.6.6. 10/24/2017
signed
H991
signed
 1.1.0-0012   IBM LT06 HH SAS 6.2.6.6. 10/24/2017,
signed
H991
signed
6.2.6.6. 10/24/2017,,
signed
HB81
signed
signed
HB81
signed
 1.1.0-0012   IBM LT08 HH FC 6.2.6.6., 10/24/2017,
signed
HB81
signed
 1.1.0-0012   IBM LT08 HH SAS  6.2.6.6, 10/24/2017,
signed
HB81
MULTISTAK 2012 8.3.0.0, 05/07/2014,
signed
1.7 - HP LTO5 HH FC 1.0.7.1, 02/11/2013,
signed
Y64B
MULTISTAK 2012 R2 8.1.0.0, 01/07/2014,
signed
1.7 - HP LTO5 HH FC 1.0.7.1, 02/11/2013, signed Y64B
signed
1.7 - HP LTO5 HH SAS 1.0.7.1, 02/11/2013, signed Z64B
signed
signed
1.7 - HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 238B
signed
signed
1.7 - HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 338B
signed
signed
1.7 - IBM LTO5 HH FC i6.2.3.3, 10/29/2012, signed E4J6
signed
1.7 - IBM LTO5 HH FC 6.2.3.3, 10/29/2012, signed E4J6
signed
1.7 - IBM LTO5 HH SAS i6.2.3.3, 10/29/2012, signed E4J6
signed
1.7 - IBM LTO5 HH SAS 6.2.3.3, 10/29/2012, signed E4J6
signed
1.7 - IBM LTO6 HH FC 6.2.3.3, 10/29/2012, signed E4J6
signed
signed
1.7 - IBM LTO6 HH SAS 6.2.3.3, 10/29/2012, signed E4J6
signed
signed
signed
signed
signed
MULTISTAK 2012\2012R2
signed
2.05
IBM LTO7 HH FC
signed
FA11
signed
2.05
IBM LTO7 HH SAS
signed
FA11
signed
2.60   IBM LTO8 HH FC  6.2.6.6,10/24/2017,
signed
HB81
signed
2.60   IBM LTO8  HH SAS 6.2.6.6, 10/24/2017,
signed
HB81
 MULTISTAK  2016
8.3.0.2, 07/03/2017,
signed
2.60   IBM LTO8 HH FC 6.2.6.6, 10/24/2017,
signed
HB81
 MULTISTAK  2016
signed
signed
HB81
Dell
Library Model Name Operating System Changer Driver Version Library Firmware Revision Tape Drive Type Tape Driver Version Tape Drive Firmware Revision
ML6000
Version v2.6.2.1, A09 585G LTO5 FH 6.1.9.9 B6W0
ML6000
Version v2.6.2.1, A09 670G LTO6 FH 6.3.9600.16384 F9A0
ML6000
Version v2.6.2.1, A09 670G LTO7 FH 6.3.9600.16384 FA10
TL1000
6.2.1.8 34 LTO5 6.2.1.8 B6W1
TL1000
6.2.3.3 58 LTO6 6.2.3.3 F9A1
TL1000
6.2.5.6 58 LTO7 6.2.5.6 FA11
TL1000    6.2.5.6 0106 LTO8 6.2.5.6 H9Ex
TL2000/4000
6.2.1.5 A.50 LTO5 HH 6.2.1.5 B171
TL2000/4000
6.2.3.3 B,60 LTO6 HH 6.2.3.3 C9T5
TL2000/4000
6.2.5.6 D.10 LTO7 HH 6.2.5.6 FA11
 ML3    6.2.6.5  1.1.1.0  LTO6  6.2.6.5  H99x
 ML3    6.2.6.5  1.1.1.0  LTO7  6.2.6.5  H9Ex
 ML3    6.2.6.5  1.1.1.0  LTO8  6.2.6.5  H9Ex
Fujitsu
Tape Driver Version
ETERNUS LT60
7.7600.16385.0, 01/02/2010, signed 4.51/3.00e LT40 HP LTO5 FH FC 1.0.6.3, 10/07/2010, signed I24B
ETERNUS LT60
7.7600.16385.0, 01/02/2010, signed 4.51/3.00e LT40, LT20 HP LTO5 HH FC 1.0.6.3, 10/07/2010, signed Y23B
ETERNUS LT60
7.7600.16385.0, 01/02/2010, signed 4.51/3.00e LT40 HP LTO5 FH SAS 1.0.6.3, 10/07/2010, signed X22B
ETERNUS LT60
7.7600.16385.0, 01/02/2010, signed 4.51/3.00e LT40, LT20 HP LTO5 HH SAS 1.0.6.3, 10/07/2010, signed Z21B
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2 HP LTO4 FH FC 1.0.7.1, 02/11/2013, signed H65B
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2 HP LTO4 FH FC 1.0.7.1, 02/11/2013, signed H65B
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2 HP LTO4 FH SAS 1.0.7.1, 02/11/2013, signed A62B
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2 HP LTO4 FH SAS 1.0.7.1, 02/11/2013, signed A62B
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO4 HH FC 1.0.7.1, 02/11/2013, signed V63B
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO4 HH FC 1.0.7.1, 02/11/2013, signed V63B
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO4 HH SAS 1.0.7.1, 02/11/2013, signed U64B
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO4 HH SAS 1.0.7.1, 02/11/2013, signed U64B
ETERNUS LT60 S2
7.7600.16385.1, 02/15/2011, signed 4.60/3.10e LT40 S2 HP LTO5 FH FC 1.0.6.3, 10/07/2010, signed I24B
ETERNUS LT60 S2
7.7600.16385.1, 02/15/2011, signed 4.60/3.10e LT40 S2, LT20 S2 HP LTO5 HH FC 1.0.6.3, 10/07/2010, signed Y34B
ETERNUS LT60 S2
7.7600.16385.1, 02/15/2011, signed 4.60/3.10e LT40 S2 HP LTO5 FH SAS 1.0.6.3, 10/07/2010, signed X22B
ETERNUS LT60 S2
7.7600.16385.1, 02/15/2011, signed 4.60/3.10e LT40 S2, LT20 S2 HP LTO5 HH SAS 1.0.6.3, 10/07/2010, signed Z21B
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 22EB
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 22EB
ETERNUS LT60 S2 2008 R2 7.7600.16385.1, 2/15/2011, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 32CB
ETERNUS LT60 S2 2012 8.0.0.1, 08/02/2012, signed 4.81/3.20e LT40 S2, LT20 S2 HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 32CB
ETERNUS LT60 S2 2012\2012R2
8.2.0.1, 05/22/2014, signed
4.88/3.20e ETERNUS LT20 S2 ETERNUS LT40 S2 IBM  LTO6
HH FC
signed
F9A1
ETERNUS LT60 S2 2012\2012R2 8.2.0.1, 05/22/2014, signed 4.88/3.20e ETERNUS LT20 S2 ETERNUS LT40 S2 IBM LTO6 HH SAS
signed
F9A1
4.88/3.20e ETERNUS LT20 S2 ETERNUS LT40 S2 IBM LTO7
HH FC
signed
FA11
4.88/3.20e ETERNUS LT20 S2 ETERNUS LT40 S2 IBM  LTO7 HH SAS
signed
FA11
ETERNUS LT60 S2 2012/2012R2
5.10/3.20e ETERNUS LT20 S2 ETERNUS LT40 S2 IBM LTO8 HH FC
6.2.6.6,10/24/2017,
signed
HB81
ETERNUS LT40 S2
IBM LTO8 HH SAS
signed
HB81
ETERNUS LT60 S2 2016
8.2.0.6, 07/03/2017, signed
ETERNUS LT40 S2
IBM LTO8 HH FC
signed
HB81
ETERNUS LT40 S2
IBM LTO8 HH SAS
signed
HB81
ETERNUS LT140 2012R2 8.2.0.1, 05/22/2014, signed 1.0.0-A00   IBM LTO6 HH FC
IBM LTO6 HH SAS
signed
JAX1
ETERNUS LT140 2012R2 8.2.0.1, 05/22/2014, signed 1.0.0-A00   IBM LTO7 HH FC
IBM LTO7 HH SAS
signed
JAY1
ETERNUS LT140 2012R2 8.2.0.1, 05/22/2014, signed 1.0.0-A00   IBM LTO8 HH FC
IBM LTO8 HH SAS
signed
JAY1
ETERNUS LT140 2016 8.2.0.6,  07/03/2017, signed 1.0.0-A00   IBM LTO6 HH FC
IBM LTO6 HH SAS
6.2.6.6,10/24/2017,
signed
JAX1
ETERNUS LT140 2016 8.2.0.6,  07/03/2017, signed 1.0.0-A00   IBM LTO7 HH FC
IBM LTO7 HH SAS
6.2.6.6,10/24/2017,
signed
JAY1
ETERNUS LT140 2016 8.2.0.6,  07/03/2017, signed 1.0.0-A00   IBM LTO8 HH FC
IBM LTO HH SAS
6.2.6.6,10/24/2017,
signed
JAY1
ETERNUS LT260 2012  8.2.0.1, 05/22/2014, signed 6.1   HP LTO4 FH FC 1.0.7.1, 02/11/2013, signed H66B
ETERNUS LT260 2012 R2 8.2.0.1, 05/22/2014, signed 6.1 HP LTO4 FH FC 1.0.7.1, 02/11/2013, signed H66B
ETERNUS LT260   8.2.0.1, 05/22/2014, signed 6.1   HP LTO4 FH FC 1.0.7.1, 02/11/2013, signed V64B
HP LTO5FH FC 1.0.7.1, 02/11/2013, signed I66B
ETERNUS LT260 2012 R2 8.2.0.1, 05/22/2014, signed 6.1   HP LTO5 FH FC 1.0.7.1, 02/11/2013, signed I66B
ETERNUS LT260 2012 8.2.0.1, 05/22/2014, signed 6.1   HP LTO5 HH FC 1.0.7.1, 02/11/2013, signed Y67B
ETERNUS LT260 2012 R2 8.2.0.1, 05/22/2014, signed 6.1   HP LTO5 HH FC 1.0.7.1, 02/11/2013, signed Y67B
ETERNUS LT260 2012 8.2.0.1, 05/22/2014, signed 6.1   HP LTO5 HH SAS
1.0.7.1, 02/11/2013, signed Z67B
ETERNUS LT260 2012 R2 8.2.0.1, 05/22/2014, signed 6.1   HP LTO5 HH SAS 1.0.7.1, 02/11/2013, signed Z67B
ETERNUS LT260 2012 8.2.0.1, 05/22/2014, signed 6.1   HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 238B
ETERNUS LT260 2012 R2 8.2.0.1, 05/22/2014, signed 6.1   HP LTO6 HH FC 1.0.7.1, 02/11/2013, signed 238B
ETERNUS LT260 2012 8.2.0.1, 05/22/2014, signed 6.1   HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 338B
ETERNUS LT260 2012R2 8.2.0.1, 05/22/2014, signed 6.1    HP LTO6 HH SAS 1.0.7.1, 02/11/2013, signed 338B
ETERNUS LT260 2012\2012R2 8.2.0.1, 05/22/2014, signed 6.71   IBMLTO6 HH FC 6.2.5.5, 09/08/2015,
signed
FA91
ETERNUS LT260 2012\2012R2 8.2.0.1, 05/22/2014, signed 6.71   IBMLTO6 HH SAS 6.2.5.5, 09/08/2015,
signed
FA91
ETERNUS LT260 2012\2012R2 8.2.0.1, 05/22/2014, signed 6.71   IBMLTO7 HH FC 6.2.5.5, 09/08/2015,
signed
FA11
6.71
IBM LTO7 HH SAS
signed
FA11
7.50   IBM LTO8 HH FC
signed
HB81
7.50   IBM LTO8 HH SAS
signed
HB81
ETERNUS LT260 2016 8.2.0.6,  07/03/2017, signed 7.50   IBM LTO8 HH FC
signed
HB81
ETERNUS LT260 2016
6.2.6.6,10/24/2017,
signed
HB81
Hewlett Packard Enterprise
Standalone Drive   N/A N/A HPE LTO7 1.0.9.1 or later  G9Q1 or later
StoreOnce VTL
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later 3.11.x or later HP LTO Drives HP StoreEver Tape Drivers for Windows v4.0.0.0 or later N/A
ESL G3
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later 680H.GS50501 MCB2 or later
656H.GS10801 MCB1 or later
HPE LTO7 FH FC
HP LTO6 FH FC
HP LTO5 FH FC
HP LTO4 FH FC
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later FA18 or later
J3PW or later
I6GW or later
H6HW or later
MSL 6480
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later 4.60 or later HPE LTO7 HH FC
HPE LTO7 HH SAS
HP LTO6 HH FC
HP LTO6 HH SAS
HP LTO5 FH FC
HP LTO5 HH FC
HP LTO5 HH SAS
HP LTO4 FH FC
HP LTO4 HH SAS
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later FA17 or later
FA17 or later
252W or later
352W or later
I6GW or later
Y6DW or later
Z6DW or later
H6FW or later
U62W or later
MSL G3 Family
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later MSL8096-1130 or later
MSL4048-8.70 or later
MSL2024-6.20 or later
HPE LTO7 HH FC
HPE LTO7 HH SAS
HP LTO6 HH FC
HP LTO6 HH SAS
HP LTO5 FH FC
HP LTO5 HH FC
HP LTO5 HH SAS
HP LTO4 FH FC
HP LTO4 HH SAS
FA17 or later
252W or later
352W or later
I6GW or later
Y6DW or later
Z6DW or later
H6FW or later
U62W or later
1/8 G2 Autoloader
HP StoreEver Tape Drivers for Windows v4.0.0.0 or later 4.30 or later HPE LTO7 HH FC
HPE LTO7 HH SAS
HP LTO6 HH FC
HP LTO6 HH SAS
HP LTO5 HH FC
HP LTO5 HH SAS
HP LTO4 HH SAS
FA17 or later
252W or later
352W or later
Y6DW or later
Z6DW or later
U62W or later
IBM
Standalone Drive
N/A N/A IBM LTO5 FH Standalone Inbox ltotape.sys
Total Storage 3572 (TS2900)
ibmcg2k12, 6.2.3.3 B.50 LTO6 HH SAS ibmcg2k12, 6.2.3.3 CB21
ibmcg2k8, 6.2.1.8, x64 17 LTO5 HH SAS ibmtp2k8, 6.2.1.8, x64 B6W1
Total Storage 3573
ibmcg2k8, 6.2.1.8, x64 A.40 IBM LTO5 3580 ibmtp2k8, 6.2.1.8, x64 B6W0
Total Storage 3573 (TS3100/TS3200)
ibmcg2k12, 6.2.3.3 B.50 LTO6 FH FC ibmcg2k12, 6.2.3.3 C9T4
ibmcg2k8, 6.2.1.8, x64 A.40 LTO4 FH FC ibmcg2k8, 6.2.1.8, x64 A230
ibmcg2k12, 6.2.3.3 B.50 LTO6 HH SAS ibmcg2k12, 6.2.3.3 C9T5
Total Storage 3576 (TS3310)
ibmcg2k12, 6.2.3.3 630G LTO6 FH FC ibmcg2k12, 6.2.3.3 CB20
Total Storage 3584 (TS3500/TS4500) 2012/2012R2 6.2.5.6 F030 LTO6 FH FC 6.2.5.6 F9A0
Total Storage 3572 (TS2900) 2012/2012R2 6.2.5.6 58 LTO7 HH SAS 6.2.5.6 FA11
Total Storage 3573 (TS3100) 2012/2012R2 6.2.5.6 D.00 LTO7 FH FC 6.2.5.6 FA10
Total Storage 3573 (TS3100) 2012/2012R2 6.2.5.6 D.00 LTO7 HH FC/SAS 6.2.5.6 FA11
Total Storage 3573 (TS3200) 2012/2012R2 6.2.5.6 D.00 LTO7 FH FC 6.2.5.6 FA10
Total Storage 3573 (TS3200) 2012/2012R2 6.2.5.6 D.00 LTO7 HH FC/SAS 6.2.5.6 FA11
Total Storage 3576 (TS3310) 2012/2012R2 6.2.5.6 670G
Total Storage 3584 (TS3500/TS4500) 2012/2012R2 6.2.5.6 F030/1201 LTO7 FH FC 6.2.5.6 F980
 Total Storage 3584
(TS4500/TS3500)
   6.2.6.6  1413/G060  LTO8  6.2.6.6  J4D0
 Total Storage 3573
(TS4300/TS3200/TS3100)
   6.2.6.6  1112/F00  LTO8  6.2.6.6  J4D0/J4D1
 Total Storage 3572
(TS2900)
   6.2.6.6  0080  LTO8  6.2.6.6  HB83
Tip: The following registry key needs to be added to enable support for TS 2900: DWORD “RSMCompatMode” under “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft Data Protection Manager\Agent” and set it to 29 (decimal)
Quantum
DXi6701 Scalar (emulating i2000)
Qi2Kx64.sys, 7.5.0.0 V 2.1.1 DXi6702 HP LTO5 hplto.sys, 1.6.0.3 I30Z
Qi2Kx64.sys, 7.5.0.0 V 2.1.1 DXi6702 IBM LTO5 ibmtp2k8.sys, 6.2.1.8 A5MO
DXi8500 2TB Scalar (emulating i2000)
Qi2Kx64.sys, 7.5.0.0 V1.5.0_85
HP LTO4 hplto.sys, 1.6.0.3 H44Z
IBM LTO4 ibmtp2k8.sys, 6.2.1.8 A2FB
DXi8502 (VTL)
Qi500X64.sys, 7.5.0.0 2.0.2_85
DXi6902 (VTL)
Qi2kx64.sys, 7.6.1.0 3.0
HP LTO5
IBM LTO5
hplto.xyx,1.0.7.1
6.2.9200.16348
I6PZ
F990
 DXi6902 (VTL) emulating Scalar i6000
 Windows 2016
 QntmLib.sys 1.0.0.1
 3.2.5    IBM LTO5
 ibmtp2k16 6.2.6.1
 A5M0
DXi4701 (VTL)
HP LTO5
IBM LTO5
hplto.xyx,1.0.7.1
6.2.9200.16348
I6PZ
F990
 DXi4701 (VTL) emulating Scalar i6000
 Windows 2016
 QntmLib.sys 1.0.0.1
3.2.5   IBM LTO5
ibmtp2k16 6.2.6.1
A5M0
Scalar i40
Qi40X64.sys, 7.5.2.0 130G
HP LTO5 hplto.sys, 1.6.0.2 Y35Z
Scalar i40
Qi40X64.sys, 7.6.0.0 175G
IBM LTO6 6.3.9600.16384 F3JD
Scalar i40
Qi40X64.sys, 7.6.0.0 180B
IBM LTO7 6.3.9600.16384 FA17
Scalar i80
Scalar i80
Scalar i80
Qi40X64.sys, 7.6.0.0 180G
Scalar i500
ad500x64.sys, 7.4.0.0 500G
IBM LTO4 ibmtp2k3.sys, 6.1.8.9 82FB
Scalar i500
Qi500X64.sys, 7.5.0.0 607G
HP LTO5 hplto.sys, 1.6.0.2 I3EZ
Scalar i500
IBM LTO5 ibmtp2k8.sys, 6.1.9.9 B170
Scalar i500
HP LTO4 hplto.sys, 1.6.0.2 H58Z
Scalar i500
Qi500x64.sys, 7.6.0.0 670G
IBM LTO6 6.3.9600.16384 F9A0
Scalar i500
IBM LTO7 6.3.9600.16384 FA10
 Scalar i500
 Windows 2016
 QtmLib 1.0.0.1
700G   IBM LTO8
ltotape 10.0.14393.206
 H7TF
Scalar i6000
Qi6Kx64.sys, 7.5.5.0 606A.GS00301 Scalar i2000 HP LTO4 FC hplto.sys, 1.6.0.1 H58Z
Scalar i6000
Qi6Kx64.sys, 7.5.5.0 606A.GS00301 Scalar i2000 HP LTO5 FC hplto.sys, 1.6.0.1 I3AZ
Scalar i6000
Qi6Kx64.sys, 7.5.5.0 606A.GS00301 Scalar i2000 IBM LTO5 FC lto.sys, 6.1.7600.16385 A6SA
Scalar i6000
Qi6Kx64.sys, 7.5.5.0 606A.GS00301 Scalar i2000 IBM LTO5 FC lto.sys, 6.1.7600.16385 B170
Scalar i6000
Qi6Kx64.sys, 7.5.5.0 606A.GS00301 Scalar i2000 IBM LTO4 FC lto.sys, 6.1.7600.16385 A23D
Scalar i6000
Qi6kx64.sys, 7.6.1.0 720Q
Scalar i6000
 Scalar i6000
 Windows 2016
 QntmLib 1.0.0.1
 760Q   IBM LTO8
 ltotape 10.0.14393.206  H980
Superloader
QsmcX64.sys, 2.5.1.0 V61
Quantum LTO4 QLTOx64.sys, 3.4.0 2103
Superloader
QsmcX64.sys, 2.6.2.0 75
Quantum LTO5 QLTOx64.sys, 3.4.0.0 3060
Superloader
QsmcX64.sys, 2.6.3.0 V91
IBM LTO5 6.3.9600.16384 F3HB
Superloader
Superloader
QsmcX64.sys, 2.6.3.0 V92
 Superloader  Windows 2016
 QntmLib,1.0.0.1
 V94    IBM LTO8
 H7TF
 Scalar i3
   6.3.9600.16384  110G   IBM LTO6 HH
6.3.9600.16384  G9P1
 Scalar i3
  6.3.9600.16384 110G   IBM LTO7 HH
6.3.9600.16384  G9Q1
 Scalar i3
 Windows 2016
 QntmLib 1.0.0.1
150G   IBM LTO8 HH
 H7TF
 Scalar i6
 6.3.9600.16384  G9P0
 Scalar i6
6.3.9600.16384  G9Q0
 Scalar i6
 Windows 2016
 QntmLib 1.0.0.1
 150G    IBM LTO8
 H7TF
Tandberg Data
StorageLoader LTO
1.8.0.11 3.47
HP 3000 LTO 5 HH SAS 1.0.6.1 Z21U
StorageLoader LTO
1.8.0.11 3.47
HP 3000 LTO 5 HH SAS 1.0.6.1 Z33U
exbchgx64.sys, 2.1.9.0, 11/21/2008, signed, 64bit V1C270
LTO4 hplto.sys, 1.0.5.2, 12/10/2007, signed, 64bit D217
exachgx64.sys, 2.1.9.0, 11/21/2008, unsigned, 64bit V1C270
LTO4 ibmtp2k8.sys, 6.1.8.9, 3/19/2008, signed, 64bit 85V3
exbchgx64.sys, 2.1.9.0, 11/21/2008, signed, 64bit V1D170
LTO4 ibmtp2k8.sys, 6.1.9.5, 6/11/2008, signed, 64bit 85V3
exachgx64.sys, 2.1.9.0, 11/21/2008, unsigned, 64bit V1D170
LTO4 ibmtp2k3.sys, 6.1.8.9, 3/19/2008, signed, 64bit 85V3
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 3000 LTO 5 HH SAS 1.0.6.1 Z21U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 3000 LTO 5 HH SAS 1.0.6.1 Z33U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 3000 LTO 5 HH FC 1.0.6.1 Y21U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 3000 LTO 5 HH FC 1.0.6.1 Y31U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 3000 LTO 5 HH FC 1.0.6.1 Y32U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 1760 LTO 4 HH FC 1.0.6.1 V51U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 1760 LTO 4 HH SAS 1.0.6.1 U51U
3.01.0009.0 V1C290 Magnum 224, StorageLoader 2U LTO HP 1760 LTO 4 HH SCSI 1.0.6.1 W51U
tdsafe.sys, 1.7.0.0, 1/4/2008, signed, 64bit 3.42
LTO4 hplto.sys, 1.0.5.2, 12/10/2007, signed, 64bit W22U
tdsafe.sys, 1.7.0.0, 1/4/2008, signed, 64bit 3.8
LTO4 ltotape.sys, 6.0.6001.18000, 6/21/2006, signed, 64bit 85V3
tdsafe.sys, 1.7.0.0, 1/4/2008, signed, 64bit 3.63
1.8.0.11 3.47
1.8.0.11 3.47
1.8.0.11 3.47
1.8.0.11 3.47
Oracle StorageTek
SL150
2.50 HP LTO5 HH FC
Y6IS
SL150
2.50 HP LTO5 HH SAS
Z6FS
SL150
2.50 HP LTO6 HH FC
25FS
SL150
2.50 HP LTO6 HH SAS
35FS
SL150
2.50 IBM LTO7 HH FC
G341
SL150-Tested
2.50 IBM LTO7 HH SAS
G341
 bdtmc.sys,
8.3.0.2,
07/03/2017,
signed
 IBM LTO6 HH FC
IBM LTO6 HH SAS
 IBM LTO6 HH FC
IBM LTO6 HH SAS
IBM LTO6 HH FC
IBM LTO6 HH FC
IBM LT06 HH FC
IBM LT06 HH SAS
2016
2016
 IBM LTO6 HH FC
IBM LTO6 HH SAS
