Data Protection Manager (DPM) in System Center 2012 R2, 2016 and 2019 can be deployed using tape-based backup for data protected by the DPM server. A tape library or stand-alone tape drive can be connected to DPM servers. For more information see Planning the Tape Libraries Configuration. The following tables summarize tape libraries that are compatible with DPM in System Center 2012 R2, 2016 and 2019.
To determine if a tape library is supported by virtual Fibre Channel adapter, contact the tape library hardware vendor or run the DPM Tape Library Compatibility Test tool. For additional information about the DPM Tape Library Compatibility Test tool, see Verify tape library compatibility.
Note: Tape libraries connected using multi-path software are not supported by DPM. Only tape libraries connected using a single path are supported.
Below libraries are only certified with physical setup of Data Protection Manager 2012 R2, Data Protection Manager 2016 or Data Protection Manager 2019.
8.1.0.0, 01/07/2014, signed
6.2.5.5, 09/08/2015, signed
8.1.0.0,01/07/2014, signed
8.3.0.0, 05/07/2014, signed
8.3.0.2, 07/03/2017, signed
8.2.0.1, 05/22/2014, signed
6.2.6.6,10/24/2017, signed
6.2.6.6, 10/24/2017, signed
8.2.0.6, 07/03/2017, signed
656H.GS10801 MCB1 or later
HP LTO6 FH FC
HP LTO5 FH FC
HP LTO4 FH FC
J3PW or later
I6GW or later
H6HW or later
HPE LTO7 HH SAS
HP LTO6 HH FC
HP LTO6 HH SAS
HP LTO5 HH FC
HP LTO5 HH SAS
HP LTO4 HH SAS
FA17 or later
252W or later
352W or later
Y6DW or later
Z6DW or later
H6FW or later
U62W or later
MSL4048-8.70 or later
MSL2024-6.20 or later
Tip: The following registry key needs to be added to enable support for TS 2900: DWORD “RSMCompatMode” under “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft Data Protection Manager\Agent” and set it to 29 (decimal)
IBM LTO5
6.2.9200.16348
F990
07/03/2017,
Exccellent
i was checking HP 2024 and 408 in this list and it says that only LTO3/4 drives are compatible.
HP state that their LTO5 and LTO6 equipment is also DPM compatible - see here at page 10:
h20565.www2.hp.com/.../resource.process
Thanks
Thanks to Jeff Walkinshaw for Table of Contents!
Does anybody know anything about footnote for Quantum Scalar i40? Is it still applicable?
Very useful information here
