Return to the MAP Toolkit Getting Started Guide
You can get more information about the MAP Toolkit by going to the following resources:
  1. The MAP Toolkit Home Page on Microsoft.com
  2. TechNet Library
  3. Frequently Asked Questions (FAQ)
  4. Self-help:
  5. To contact us:
    • Support offerings and regional contact information can be found at http://support.microsoft.com/common/international.aspx
    • Premier customers can contact Premier Support for assistance. If you open a case, choose “Server 2008 R2” for the eligible product. Then set the “Routing Product” to “Assessment & Planning Sol Acc EN” so it will get routed to the right team.
    • Email us directly at mapfdbk@microsoft.com
  6. Other Resources:
  7. The ReadMe provides release notes and information you should read before installing the MAP Toolkit, including installation prerequisites and known issues. You can download the ReadMe information from the Microsoft Assessment and Planning Toolkit page on the Microsoft Download Center.
