Many Wiki articles use colors. Unfortunately, in some cased the colors specified in HTML using RGB values are not displayed correctly (it seems to be linked to the browser version used by the editor.)
This script provides a way to load the HTML source code into memory (by using copy, ctrl+c), then using a script to replace the RGB codes in color names, and pasting back the HTML code into the Wiki article.
See Also:  Wiki: Fix Color Issues in Wiki Articles
How to use
  1. Download the script from gallery or copy the source code into a local PowerShell script.
  2. Open the Wiki article in edit mode
  3. Go to the HTML source code from the article.
  4.  Copy the entire HTML content in memory. Select all text (ctrl+a) then copy the text (ctrl+C).
  5.  Run the script
  6.  Paste the update HTML code from memory into the article edit window (ctrl+V).
Gallery
 http://gallery.technet.microsoft.com/Powershell-to-fix-RGB-56f80509
Source Code
# Author: Peter Geelen
# e-mail: peter@ffwd2.me
# Web: blog.identityunderground.be
# Credits: http://brianreiter.org/2010/09/03/copy-and-paste-with-clipboard-from-powershell/
# Core references:
# http://social.technet.microsoft.com/wiki/contents/articles/16870.wiki-fix-color-issues-in-wiki-articles.aspx
#Set-PSDebug -Trace 2
Set-PSDebug -off
Function pause
 PARAM($msg ="")
 END
 $message = $msg +"... (Press any key to continue) ..."
 Write-Host $message
 $x = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown")
Function LoadColor
 PARAM($sRGBCode ="", $sName ="")
 END
 $newRecord = new-object psobject
 $newRecord | Add-Member NoteProperty RGBCode $sRGBCode
 $newRecord | Add-Member NoteProperty Name $sName
 return $newRecord
Function LoadColorList
 $sRGBList = @()
 $sRGBList += LoadColor -sRGBCode "rgb(0, 0, 0)" -sName "Black"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 0, 128)" -sName "Navy"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 0, 139)" -sName "DarkBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 0, 205)" -sName "MediumBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 0, 255)" -sName "Blue"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 100, 0)" -sName "DarkGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 102, 0)" -sName "DarkGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 128, 0)" -sName "Green"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 128, 128)" -sName "Teal"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 139, 139)" -sName "DarkCyan"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 191, 255)" -sName "DeepSkyBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 206, 209)" -sName "DarkTurquoise"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 250, 154)" -sName "MediumSpringGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 255, 0)" -sName "Lime"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 255, 127)" -sName "SpringGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 255, 255)" -sName "Aqua"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 255, 255)" -sName "Cyan"
 $sRGBList += LoadColor -sRGBCode "rgb(25, 25, 112)" -sName "MidnightBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(30, 144, 255)" -sName "DodgerBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(32, 178, 170)" -sName "LightSeaGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(34, 139, 34)" -sName "ForestGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(46, 139, 87)" -sName "SeaGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(47, 79, 79)" -sName "DarkSlateGray"
 $sRGBList += LoadColor -sRGBCode "rgb(47, 79, 79)" -sName "DarkSlateGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(50, 205, 50)" -sName "LimeGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(60, 179, 113)" -sName "MediumSeaGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(64, 224, 208)" -sName "Turquoise"
 $sRGBList += LoadColor -sRGBCode "rgb(65, 105, 225)" -sName "RoyalBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(70, 130, 180)" -sName "SteelBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(72, 61, 139)" -sName "DarkSlateBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(72, 209, 204)" -sName "MediumTurquoise"
 $sRGBList += LoadColor -sRGBCode "rgb(75, 0, 130)" -sName "Indigo"
 $sRGBList += LoadColor -sRGBCode "rgb(85, 107, 47)" -sName "DarkOliveGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(95, 158, 160)" -sName "CadetBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(100, 149, 237)" -sName "CornflowerBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(102, 205, 170)" -sName "MediumAquamarine"
 $sRGBList += LoadColor -sRGBCode "rgb(105, 105, 105)" -sName "DimGray"
 $sRGBList += LoadColor -sRGBCode "rgb(105, 105, 105)" -sName "DimGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(106, 90, 205)" -sName "SlateBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(107, 142, 35)" -sName "OliveDrab"
 $sRGBList += LoadColor -sRGBCode "rgb(112, 128, 144)" -sName "SlateGray"
 $sRGBList += LoadColor -sRGBCode "rgb(112, 128, 144)" -sName "SlateGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(119, 136, 153)" -sName "LightSlateGray"
 $sRGBList += LoadColor -sRGBCode "rgb(119, 136, 153)" -sName "LightSlateGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(123, 104, 238)" -sName "MediumSlateBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(124, 252, 0)" -sName "LawnGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(127, 255, 0)" -sName "Chartreuse"
 $sRGBList += LoadColor -sRGBCode "rgb(127, 255, 212)" -sName "Aquamarine"
 $sRGBList += LoadColor -sRGBCode "rgb(128, 0, 0)" -sName "Maroon"
 $sRGBList += LoadColor -sRGBCode "rgb(128, 0, 128)" -sName "Purple"
 $sRGBList += LoadColor -sRGBCode "rgb(128, 128, 0)" -sName "Olive"
 $sRGBList += LoadColor -sRGBCode "rgb(92, 92, 92)" -sName "Grey"
 $sRGBList += LoadColor -sRGBCode "rgb(128, 128, 128)" -sName "Gray"
 $sRGBList += LoadColor -sRGBCode "rgb(128, 128, 128)" -sName "Grey"
 $sRGBList += LoadColor -sRGBCode "rgb(135, 206, 235)" -sName "SkyBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(135, 206, 250)" -sName "LightSkyBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(138, 43, 226)" -sName "BlueViolet"
 $sRGBList += LoadColor -sRGBCode "rgb(139, 0, 0)" -sName "DarkRed"
 $sRGBList += LoadColor -sRGBCode "rgb(139, 0, 139)" -sName "DarkMagenta"
 $sRGBList += LoadColor -sRGBCode "rgb(139, 69, 19)" -sName "SaddleBrown"
 $sRGBList += LoadColor -sRGBCode "rgb(143, 188, 143)" -sName "DarkSeaGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(144, 238, 144)" -sName "LightGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(147, 112, 219)" -sName "MediumPurple"
 $sRGBList += LoadColor -sRGBCode "rgb(148, 0, 211)" -sName "DarkViolet"
 $sRGBList += LoadColor -sRGBCode "rgb(152, 251, 152)" -sName "PaleGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(153, 50, 204)" -sName "DarkOrchid"
 $sRGBList += LoadColor -sRGBCode "rgb(154, 205, 50)" -sName "YellowGreen"
 $sRGBList += LoadColor -sRGBCode "rgb(160, 82, 45)" -sName "Sienna"
 $sRGBList += LoadColor -sRGBCode "rgb(165, 42, 42)" -sName "Brown"
 $sRGBList += LoadColor -sRGBCode "rgb(169, 169, 169)" -sName "DarkGray"
 $sRGBList += LoadColor -sRGBCode "rgb(169, 169, 169)" -sName "DarkGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(173, 216, 230)" -sName "LightBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(173, 255, 47)" -sName "GreenYellow"
 $sRGBList += LoadColor -sRGBCode "rgb(175, 238, 238)" -sName "PaleTurquoise"
 $sRGBList += LoadColor -sRGBCode "rgb(176, 196, 222)" -sName "LightSteelBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(176, 224, 230)" -sName "PowderBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(178, 34, 34)" -sName "FireBrick"
 $sRGBList += LoadColor -sRGBCode "rgb(184, 134, 11)" -sName "DarkGoldenrod"
 $sRGBList += LoadColor -sRGBCode "rgb(186, 85, 211)" -sName "MediumOrchid"
 $sRGBList += LoadColor -sRGBCode "rgb(188, 143, 143)" -sName "RosyBrown"
 $sRGBList += LoadColor -sRGBCode "rgb(189, 183, 107)" -sName "DarkKhaki"
 $sRGBList += LoadColor -sRGBCode "rgb(192, 192, 192)" -sName "Silver"
 $sRGBList += LoadColor -sRGBCode "rgb(199, 21, 133)" -sName "MediumVioletRed"
 $sRGBList += LoadColor -sRGBCode "rgb(205, 92, 92)" -sName "IndianRed"
 $sRGBList += LoadColor -sRGBCode "rgb(205, 133, 63)" -sName "Peru"
 $sRGBList += LoadColor -sRGBCode "rgb(210, 105, 30)" -sName "Chocolate"
 $sRGBList += LoadColor -sRGBCode "rgb(210, 180, 140)" -sName "Tan"
 $sRGBList += LoadColor -sRGBCode "rgb(211, 211, 211)" -sName "LightGray"
 $sRGBList += LoadColor -sRGBCode "rgb(211, 211, 211)" -sName "LightGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(216, 191, 216)" -sName "Thistle"
 $sRGBList += LoadColor -sRGBCode "rgb(218, 112, 214)" -sName "Orchid"
 $sRGBList += LoadColor -sRGBCode "rgb(218, 165, 32)" -sName "Goldenrod"
 $sRGBList += LoadColor -sRGBCode "rgb(219, 112, 147)" -sName "PaleVioletRed"
 $sRGBList += LoadColor -sRGBCode "rgb(220, 20, 60)" -sName "Crimson"
 $sRGBList += LoadColor -sRGBCode "rgb(220, 220, 220)" -sName "Gainsboro"
 $sRGBList += LoadColor -sRGBCode "rgb(221, 160, 221)" -sName "Plum"
 $sRGBList += LoadColor -sRGBCode "rgb(222, 184, 135)" -sName "BurlyWood"
 $sRGBList += LoadColor -sRGBCode "rgb(224, 255, 255)" -sName "LightCyan"
 $sRGBList += LoadColor -sRGBCode "rgb(230, 230, 250)" -sName "Lavender"
 $sRGBList += LoadColor -sRGBCode "rgb(233, 150, 122)" -sName "DarkSalmon"
 $sRGBList += LoadColor -sRGBCode "rgb(238, 130, 238)" -sName "Violet"
 $sRGBList += LoadColor -sRGBCode "rgb(238, 232, 170)" -sName "PaleGoldenrod"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 128, 128)" -sName "LightCoral"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 230, 140)" -sName "Khaki"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 248, 255)" -sName "AliceBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 255, 240)" -sName "Honeydew"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 255, 255)" -sName "Azure"
 $sRGBList += LoadColor -sRGBCode "rgb(244, 164, 96)" -sName "SandyBrown"
 $sRGBList += LoadColor -sRGBCode "rgb(245, 222, 179)" -sName "Wheat"
 $sRGBList += LoadColor -sRGBCode "rgb(245, 245, 220)" -sName "Beige"
 $sRGBList += LoadColor -sRGBCode "rgb(245, 245, 245)" -sName "WhiteSmoke"
 $sRGBList += LoadColor -sRGBCode "rgb(245, 255, 250)" -sName "MintCream"
 $sRGBList += LoadColor -sRGBCode "rgb(248, 248, 255)" -sName "GhostWhite"
 $sRGBList += LoadColor -sRGBCode "rgb(250, 128, 114)" -sName "Salmon"
 $sRGBList += LoadColor -sRGBCode "rgb(250, 235, 215)" -sName "AntiqueWhite"
 $sRGBList += LoadColor -sRGBCode "rgb(250, 240, 230)" -sName "Linen"
 $sRGBList += LoadColor -sRGBCode "rgb(250, 250, 210)" -sName "LightGoldenrodYellow"
 $sRGBList += LoadColor -sRGBCode "rgb(253, 245, 230)" -sName "OldLace"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 0, 0)" -sName "Red"
 $sRGBList += LoadColor -sRGBCode "rgb(204, 0, 0)" -sName "Red"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 0, 255)" -sName "Fuchsia"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 0, 255)" -sName "Magenta"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 20, 147)" -sName "DeepPink"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 69, 0)" -sName "OrangeRed"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 99, 71)" -sName "Tomato"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 105, 180)" -sName "HotPink"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 127, 80)" -sName "Coral"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 140, 0)" -sName "DarkOrange"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 160, 122)" -sName "LightSalmon"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 165, 0)" -sName "Orange"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 182, 193)" -sName "LightPink"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 192, 203)" -sName "Pink"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 215, 0)" -sName "Gold"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 218, 185)" -sName "PeachPuff"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 222, 173)" -sName "NavajoWhite"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 228, 181)" -sName "Moccasin"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 228, 196)" -sName "Bisque"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 228, 225)" -sName "MistyRose"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 235, 205)" -sName "BlanchedAlmond"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 239, 213)" -sName "PapayaWhip"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 240, 245)" -sName "LavenderBlush"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 245, 238)" -sName "Seashell"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 248, 220)" -sName "Cornsilk"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 250, 205)" -sName "LemonChiffon"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 250, 240)" -sName "FloralWhite"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 250, 250)" -sName "Snow"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 255, 0)" -sName "Yellow"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 255, 224)" -sName "LightYellow"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 255, 240)" -sName "Ivory"
 $sRGBList += LoadColor -sRGBCode "rgb(255, 255, 255)" -sName "White"
## non mathching codes with closest match
 $sRGBList += LoadColor -sRGBCode "rgb(42, 42, 42)" -sName "darkSlateGray"
 $sRGBList += LoadColor -sRGBCode "rgb(163, 163, 163)" -sName "darkGray"
 $sRGBList += LoadColor -sRGBCode "rgb(240, 240, 240)" -sName "whiteSmoke"
 $sRGBList += LoadColor -sRGBCode "rgb(242, 242, 242)" -sName "whiteSmoke"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 102, 221)" -sName "DeepSkyBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(38, 38, 38)" -sName "DarkSlateGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(51, 51, 51)" -sName "DarkSlateGrey"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 102, 153)" -sName "cornflowerblue"
 $sRGBList += LoadColor -sRGBCode "rgb(248, 248, 248)" -sName "WhiteSmoke"
 $sRGBList += LoadColor -sRGBCode "rgb(0, 130, 0)" -sName "Green"
 $sRGBList += LoadColor -sRGBCode "rgb(127, 157, 185)" -sName "SteelBlue"
 $sRGBList += LoadColor -sRGBCode "rgb(163, 21, 21)" -sName "Red"
 $sRGBList += LoadColor -sRGBCode "rgb(43, 145, 175)" -sName "cornflowerblue"
 $sRGBList += LoadColor -sRGBCode "rgb(46, 117, 181)" -sName "Royalblue"
 return $sRGBList
function Set-ClipboardText()
 PARAM($sText ="")
 END
 $Text | clip
# MAIN
$a= (Get-Host).UI.RawUI
$a.="RGB code replacer"
$b= $a.WindowSize
Clear-Host
# create RGBCode list to convert
Write-host "Initialising... Please wait..."
Write-host "Initialising... Loading RGB color list..."
$RGBList = @()
$RGBList = LoadColorlist
Write-host "Starting RGB conversion... Please wait..."
pause"Now go to HTML page, copy HTML source into memory/clipboard."
cls$SourceText = & {powershell –sta {add-type –a system.windows.forms; [windows.forms.clipboard]::GetText()}}
Write-host "Copied clipboard"
Write-host "Converting... Using RGB color list..."
foreach ($RGB in $RGBList)
$SourceText = $SourceText.replace($RGB.RGBCode, $RGB.Name)
if$SourceText -match"rgb\(")
 Write-Host "WARNING: the text in memory contains unmapped RGB Codes!!" -foregroundcolor white -backgroundcolor darkred
# process RGB codes from memory
#writing transformed data back to memory
pause"Now go back to the HTML page, now paste HTML source into memory/clipboard."
$SourceText | clip
#$SourceText -match"rgb\("
#pause $SourceText
pause"Command completed successfully"
TrapWrite-Host "`nError: $($_.Exception.Message)`n" -foregroundcolor white -backgroundcolor darkred
 Exit 1
