FIM ScriptBox Item
Summary:
The FIM MA Attribute Flow Documenter generates a report of the import and export attribute flow configuration of your FIM MA.
 Important
To run the script, you need a FIM server with PowerShell installed.
If you have installed PowerShell on your FIM server, make sure that it is configured to allow running scripts. The command to verify this is “get-executionpolicy”. To enable all Windows PowerShell scripts to run, use the following command: "set-executionpolicy unrestricted". Please see the PowerShell documentation for more details.
Download:
 Important
After you have downloaded the Zip file to your computer, you should unblock it.
To unblock the file, right-click it, select Properties, and then click Unblock.
note Note
To provide feedback about this script, create a post on the FIM TechNet Forum.
For more FIM related Windows PowerShell scripts, see the FIM ScriptBox.
