This article has its origin in a question posted in <forum name> forum: <forum thread name> and will provide you with a solution, or common solutions, and will try to explain what’s the best way to address and solve this problem.
Question or Problem
This section is a summary of the issue – what happened/what’s wrong.
Possible Solutions
This section will describe the problem or problems, why they apply and the way to solve or to workaround the problem.
Solution 1
Section to describe all the steps necessary to describe the solution.
Limitations of this approach
Section to describe the limitations of this approach.
Advantages of this approach
Section to describe the advantages of this approach.
Solution 2
Section to describe all the steps necessaries to describe the solution.
Section to put additional information like what's the best approach.
Code Sample
Section to put additional links to all code samples available.
Other Languages
This article can also be found in the following languages​​:
  • List All Languages ​​this article was translated into
Read suggested related topics:
  • List of articles
Another important place to find a huge amount of <technology> related articles is the TechNet Wiki itself. The best entry point is <link to list of articles>.
This article is part of the Template Articles for Forums collection and can also be found in the following languages​​:
Please do not put any additional content  above the dash if it is not in the context template. The purpose of this template is to copy the entire section above the dash and paste to your own article.
