This article provides a comparison between System.Xml.XMLDocument and System.Xml.Linq.XDocument. My main purpose of writing this wiki was to explore the System.Xml.Linq library as until recently I mostly used the System.Xml library.
I decided to implement the following scenario for both libraries:
  1. Retrieve an xml feed from the blogs.msdn.com RSS service.
  2. Save the xml feed to a file
  3. Update the in memory xml document by inserting a couple of items
  4. Retrieve the xml feed from the file
The two main criteria I wanted to measure was overall performance of the classes involved and programming convenience.  By programming convenience, I mostly mean was the scenario easy to code and how maintainable (e.g., readable).
System.Xml.Linq.XDocument did make this step incredibly easy:
XDocument xDoc = XDocument.Load("http://blogs.msdn.com/b/mainfeed.aspx?Type=BlogsOnly");
System.Xml.XmlDocument  took a bit more effort in first creating a WebRequest to stream the content into the document's Load() method:
System.Net.WebRequest wRequest = System.Net.WebRequest.Create("http://blogs.msdn.com/b/mainfeed.aspx?Type=BlogsOnly");
System.Net.WebResponse wResponse = wRequest.GetResponse();
System.IO.Stream rssStream = wResponse.GetResponseStream();
XmlDocument xDoc = new XmlDocument();
xDoc.Load(rssStream);
Save the xml feed to file
Both libraries provide a single Save() method for saving to file.  For example,
xDoc.Save("RetrieveFeedXDocumentTests.xml");
From a programming convenience point of view, System.Xml.Linq.XDocument provides a succinct and rich set of methods.  For example, compare the following:
xDoc.Descendants("item").Last()
                        .AddAfterSelf(new XElement("item",
                                        new XElement("title", "title1"),
                                        new XElement("link", "link1"),
                                        new XElement("guid",
                                            new XAttribute("isPermaLink", "false"),
                                            new XText(Guid.NewGuid().ToString()))),
                                            new XElement("title", "title2"),
                                            new XElement("link", "link2"),
                                                new XText(Guid.NewGuid().ToString()))));
with the equivalent System.Xml.XMLDocument:
var xElementItem = xDoc.CreateElement("item");
// title
var xTempElement = xDoc.CreateElement("title");
xTempElement.InnerText = "title1";
xElementItem.AppendChild(xTempElement);
// link
xTempElement = xDoc.CreateElement("link");
xTempElement.InnerText = "link1";
// guid
xTempElement = xDoc.CreateElement("guid");
var xAttribute = xDoc.CreateAttribute("isPermaLink");
xAttribute.Value = "false";
xTempElement.AppendChild(xDoc.CreateTextNode(Guid.NewGuid().ToString()));
xTempElement.Attributes.Append(xAttribute);
xDoc.SelectSingleNode("./rss/channel").AppendChild(xElementItem);
// second item
// title
xTempElement.InnerText = "title2";
// link
xTempElement.InnerText = "link2";
// guid
xDoc.SelectSingleNode("./rss/channel").LastChild.AppendChild(xElementItem);
Note: I do recognize that I could create methods to assist in building the document.
Retrieve the xml feed from file
Both System.Xml.Linq.XDocument and System.Xml.XmlDocument provide a single method for loading an xml document from a file.  The XDocument example is:
xDoc = XDocument.Load("RetrieveFeedXDocumentTests.xml");
While XmlDocument is:
xDoc.Load("RetrieveFeedXMLDocumentTests.xml");
Performance
Based on other articles I have read about the two technologies, I was expecting a more significant difference in performance where the Linq xml library showed better performance.  I did not though, and found a very slight performance difference in favor of the older System.Xml library:
Linq XDocument Average: 4191
XmlDocument Average: 3829
Please see the MSDN project for full source code: http://code.msdn.microsoft.com/SystemXmlXMLDocument-and-1e664e58
