Problem
The user is getting the following error on his Surface Pro 2 device when trying to connect to a wireless network:
"Install a driver for your network adapter - Windows could not detect a properly installed network adapter. If you have a network adapter you will need to re-install the driver."
Solution
Go through the steps to troubleshoot as described in Can’t connect to a wireless network
You may also try the following steps:
 Caution
Don’t use this process on Surface RT or Surface 2.
See: http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on?lc=1033
  1. Power off Surface Pro 2.
  2. Hold Volume Up and the Power button for  about 10 seconds.
  3. Now release buttons.
  4. Wait for a few seconds.
  5. Press and release Power button of  Surface Pro 2 to restart.
