Small Basic: Reference Documentation > Text
Text
The Text object provides helpful operations for working with Text.
Operations
  Append
Text.Append(text1, text2)
Appends two text inputs and returns the result as another text. This operation is particularly useful when dealing with unknown text in variables which could accidentally be treated as numbers and get added, instead of getting appended.
text1
First part of the text to be appended.
text2
Second part of the text to be appended.
Returns
The appended text containing both the specified parts.
  GetLength
Text.GetLength(text)
Gets the length of the given text.
text
The text whose length is needed.
Returns
The length of the given text.
  IsSubText
Text.IsSubText(text, subText)
Gets whether or not a given subText is a subset of the larger text.
text
The larger text within which the sub-text will be searched.
subText
The sub-text to search for.
Returns
True if the subtext was found within the given text.
  EndsWith
Text.EndsWith(text, subText)
Gets whether or not a given text ends with the specified subText.
text
The larger text to search within.
subText
Returns
True if the subtext was found at the end of the given text.
  StartsWith
Text.StartsWith(text, subText)
Gets whether or not a given text starts with the specified subText.
text
subText
Returns
True if the subtext was found at the start of the given text.
  GetSubText
Text.GetSubText(text, start, length)
Gets a sub-text from the given text.
text
The text to derive the sub-text from.
start
Specifies where to start from.
length
Specifies the length of the sub text.
Returns
The requested sub-text
  GetSubTextToEnd
Text.GetSubTextToEnd(text, start)
Gets a sub-text from the given text from a specified position to the end.
text
start
Returns
The requested sub-text.
  GetIndexOf
Text.GetIndexOf(text, subText)
Finds the position where a sub-text appears in the specified text.
text
The text to search in.
subText
The text to search for.
Returns
The position at which the sub-text appears in the specified text. If the text doesn't appear, it returns 0.
  ConvertToLowerCase
Text.ConvertToLowerCase(text)
Converts the given text to lower case.
text
The text to convert to lower case.
Returns
The lower case version of the given text.
  ConvertToUpperCase
Text.ConvertToUpperCase(text)
Converts the given text to upper case.
text
The text to convert to upper case.
Returns
The upper case version of the given text.
  GetCharacter
Text.GetCharacter(characterCode)
Given the unicode character code, gets the corresponding character, which can then be used with regular text.
characterCode
The character code (Unicode based) for the required character.
Returns
A unicode character that corresponds to the code specified.
  GetCharacterCode
Text.GetCharacterCode(character)
Given a unicode character, gets the corresponding character code.
character
The character whose code is requested.
Returns
A unicode based code that corresponds to the character specified.
