Small Basic: Reference Documentation > Timer
Timer
The Timer object provides an easy way for doing something repeatedly with a constant interval between.
Properties
  Interval
Timer.Interval
Gets or sets the interval (in milliseconds) specifying how often the timer should raise the Tick event. This value can range from 10 to 100000000
Events
  Tick
Timer.Tick
Raises an event when the timer ticks.
Operations
  Pause
Timer.Pause()
Pauses the timer. Tick events will not be raised.
Returns
Nothing
  Resume
Timer.Resume()
Resumes the timer from a paused state. Tick events will now be raised.
Returns
Nothing
