Source reference
This article has originally been posted on the (now archived) ILM forum. Therefore it has been ported to the TN Wiki for continued maintenance.
Hub-and-spoke GALSync
In case you wish to implement a hub-and-spoke infrastructure for your Global Address List Sync with ILM/FIM, you need to tune the original GALSync setup.
Hub-and-spoke architecture means one master GAL domain which communicates with slave domains, without direct provisioning between slave domains.
For ease of use, I've put the decision logic in one function (shouldprovision).
In the GALMV.vb file you need to create a private function (based on VB.NET code):
Private Function shouldprovision( _         ByVal currentMVentry As MVEntry, _
     ByVal mANAme As String) As Boolean
    'The only domain and MA name you need to know is the master domain
    'The master domain name is the FQDN of the AD domain
    'this is compared with the msOriginationForest attribute
    Const masterDomain As String = "g1.local" 'msOriginatingForest format
    'The master MA Name is the GALSync MA Name in the ILM GUI
    Const masterMAName As String = "GALSYNC1" 'MA NAME
    Dim IsHub As Boolean = _
           currentMVentry(EXCH_ORIGINATING_FOREST).StringValue.Equals(masterDomain)
    Dim IsSpoke As Boolean = (Not mANAme.Equals(masterMAName))
    'Provisioning OK if
          '1. source = hub and target = spoke
          '2. source = spoke and target = hub
    'Provisioning NOT OK if
          'source = spoke and target = spoke
    'Sample configuration with Hub: GAL1, spokes = GAL2,GAL3
       'See Truth table below
    'The function who matches this functionality is an inverted XOR
    Return Not (IsSpoke Xor IsHub)
End Function
Truth table:
'Source MA
Target MA
isHub
IsSpoke
ShouldProvision Result
GAL1
GAL2
TRUE
TRUE
TRUE
GAL1
GAL3
TRUE
TRUE
TRUE
GAL2
GAL1
FALSE
FALSE
TRUE
GAL2
GAL3
FALSE
TRUE
FALSE
GAL3
GAL1
FALSE
FALSE
TRUE
GAL3
GAL2
FALSE
TRUE
FALSE
In the Sub Provision of the GALMV.vb extension, add a call to the ShouldProvision function, like
For i = 0 To galMAs.Length - 1
     MA = mventry.ConnectedMAs(galMAs(i).MAName)
     If 0 = MA.Connectors.Count Then
     ' If there were no connectors, then we are going to add one
     '## NEW CODE SNIPPET##>
     If shouldprovision(mventry, galMAs(i).MAName) THEN _ '<## NEW CODE SNIPPET##
     AddOrRenameConnector(MA, galMAs(i), mventry)
     ElseIf 1 = MA.Connectors.Count Then
In this way the provisioning is blocked if not allowed.
See also:
