Background
This solution can be used to replicate native MS Office expandable/collapsible headers which is not available Out-of-the-box in SharePoint.
This technique is very useful in creating Publishing Pages and FAQs.
Code
The simple jQuery below does all the work. You can implement this either by adding a Script Editor on your page or adding it on your Page Layout.
For this wiki we'll just use a Script Editor.
The code targets all the headers on your page [h1 - h6]. SharePoint Headers only uses up to h4.
<script src="//code.jquery.com/jquery-1.11.2.min.js"></script>
<script type="text/javascript">
$(document).ready(function(){
 $(":header").css("line-height", "0%");
 $(":header").css("border-top", "5px solid transparent");
 $(":header").css("border-bottom", "5px solid transparent");
 $(":header").css("border-left", "5px solid black");
 $(":header").css("padding-left", "5px");
 $(":header").css("margin-bottom", "10px");
 //Cancel out the title Style
 $(":header:first").removeAttr("style");;
 $(":header").click(function(){
 $(this).nextUntil(":header").toggle();
</script>
Implementation
Edit your SharePoint Page and click Insert then Embed Code:
  • Paste the code snippet above. You can point to the local jQuery file in your Script Library instead of using //code.jquery.com
  • Now on your Page Content, Type in a sample header and click Format Text. You can choose from Header 1 - Header 4. This is basically just h1 to h4 in HTML terms:
As you can see on the image above,  the "What You Need" text has been set to use Heading 2 (disregard the highlighted Heading 3).
There is also some plain text below. All that text below the header will be included in the collapsible content.
Here's how it looks expanded:
Now collapsed
It is also possible to have sub-headers, as seen below on point 2.1
You now have an expandable/collapsible header functionality for your SharePoint pages which is very easy to implement and easy to understand for your end users.
Notes:
Edited the Script to include an arrow prefix on each header.
Headers should now look like this
