-     Create an Azure account
Go “setting” and assign the user as the Co-administrator
-     Select automation and create an Automation Account, in this example “gwauto"
-     Select the created Automation Account
-     Create a new runbook, in the example, “shutdown-vm”
-     Click runbook “shutdown-vm” to create/edit a script
-     Click Author -> insert script -> Test -> Publish
===================== Script example of shutdown-vm=====================
workflow shutdown-vm
$username = "azureauto@mfa01.onmicrosoft.com"
$pass = "      "
$password=$pass|ConvertTo-SecureString -AsPlainText -Force
$mycred = new-object -typename System.Management.Automation.PSCredential -argumentlist $username,$password
Add-AzureAccount -Credential $mycred
$AzureSubscriptions = Get-AzureSubscription
foreach ($subscription in $AzureSubscriptions)
    Select-AzureSubscription -SubscriptionName $subscription.SubscriptionName
    #Write-Host $subscription.SubscriptionName
    foreach ($vm in Get-AzureVM)
        $name = $vm.Name
        $servicename = $vm.ServiceName
        If($vm.Status -ne 'StoppedDeallocated')
            # Add the VM's which should not be shutdown
            Stop-AzureVM -Service $servicename -name $name -Force
-     Schedule the runbook
