This article shows you how to write a program that finds the average value of a set of N scores entered by your user, where N can be any value. You can start by asking your user how many scores he has, and then use a For loop to read his inputs. Listing 1 shows you how to do this.
For Loop
Listing 1: Find the average of scores
1 ' Average1.sb
2 TextWindow.Write("How many scores do you have? ")
3 count = TextWindow.ReadNumber()
4 sum = 0
5 For N = 1 To count
6   TextWindow.Write("Enter score " + N + ": ")
7   sum = sum + TextWindow.ReadNumber()
8 EndFor
9 TextWindow.WriteLine("Average = " + (sum/count) )
Your program asks your user how many scores he has (Line 2), saves the answer in the count variable (Line 3), and then starts a For loop with a terminal value set to count. Each time, the loop asks him for a new score that gets added to the running total, sum (Lines 5-8). When the loop ends, the program calculates the average and displays it (Line 9).
Here’s an example of what it might look like to your user:
How many scores do you have? 4
Enter score 1: 90
Enter score 2: 85
Enter score 3: 95
Enter score 4: 88
Average = 89.5
While Loop
Another way to write this program is to have your user enter a sentinel value (a special flag) when he’s done. (For example, you might ask your user to enter “-99” when he’s finished.) Of course, you must choose the sentinel so that it can’t be confused with the data. For example, if your program expects a list of names or positive numbers, a sentinel of –1 is a good choice. But if it expects the user to enter negative values, then a sentinel of –1 isn’t a good idea.
Back to our example! Let’s work through our averaging program using a sentinel of –1. The complete program’s in Listing 2.
Listing 2: Finds the average of a variable number of scores
 1 ' Average2.sb
 2 sum   = 0
 3 num   = 0
 4 count = 0
 5 While (num <> -1 )
 6   TextWindow.Write("Score " + (count+1) + " [-1 when done]: ")
 7   num = TextWindow.ReadNumber()
 8   If (num <> -1) Then
 9     sum = sum + num
10     count = count + 1
11   EndIf
12 EndWhile
13 TextWindow.WriteLine("Average = " + (sum/count))
Since the number of scores isn’t known in advance, you’ll want to use a While loop. Each time the loop prompts your user to enter a number (Line 6). Note that the value of the sentinel (–1 in this case) is stated in the prompt. The value entered by your user is then compared to the sentinel value (Line 8). If she enters –1, the While loop terminates, passing the control out to Line 13. Otherwise, her input value’s added to the running total (Line 9), and the loop runs again to prompt her for her next entry.
Here’s an example where she enters four numbers before entering the sentinel value:
Score 1 [-1 when done]: 90
Score 2 [-1 when done]: 85
Score 3 [-1 when done]: 95
Score 4 [-1 when done]: 88
Score 5 [-1 when done]: -1
Average = 89.5
In review, a Sentinel Value is a value entered by your user to notify that she's done entering data.
Credits
This article was originally written by Ed Price and Majed Marji for the Small Basic blog.
Additional Resources
