Create a new project, Add a new item and then select user control
Adding User Control
Then go to MyUserControl1.xaml and add textblock and image from toolbox.
User Control
Now we want to give the control to the user using our custom control so he/she can change text and image. For that go to MyUserControl1.xaml.cs and add a dependency property of type as of the 'text' property of textblock i.e string. In this case set metadata to 'null'.
Dependency Property
Do the same for source of the image of the type 'ImageSource'
Dependency Property
Now bind the respected properties with our dependency properties so they can be changed by the user
Data Binding
Data Binding
Now we can use our created custom control anywhere we like. And can change the text or image source to add any image
Using Custom Control
Like this we can give the desired control over our custom control to the user by binding them with our created dependency properties.
Source Code: https://github.com/umerqureshi93/CustomControl
Adding User Control
User Control
Dependency Property
Dependency Property
Data Binding
Data Binding
Adding User Control
User Control
Dependency Property
Dependency Property
Data Binding
Data Binding
Adding User Control
User Control
Dependency Property
Dependency Property
Data Binding
Data Binding
