The goal of this article is to provide a simple and easy to use error handling mechanism within triggers context. This article is completely compatible with SQL Server 2012 and 2014.
Problem Definition
Triggers are strange objects that have their own rules!
  • First rule says that triggers are part of the invoking transaction (the transaction that fired them). Yes, this is True and it means that at the beginning of the trigger, both values of @@trancount and xact_state() are "1". So, if we use COMMIT or ROLLBACK inside the trigger, their values will change to "0" just after executing these statements.
  • Second strange rule is that if the transaction ended in the trigger, the database raises an abortion error. An example for this rule is executing COMMIT or ROLLBACK within the trigger.
Next code shows these rules:
-- create test table
IF OBJECT_ID('dbo.Test', 'U') IS NOT NULL
  DROP TABLE dbo.Test ;
GO
CREATE TABLE dbo.Test
  ( Id INT IDENTITY PRIMARY KEY,
    NAME NVARCHAR(128)
GO
-- create test trigger
CREATE TRIGGER dbo.TriggerForTest
   ON  dbo.Test
   AFTER INSERT
AS
BEGIN
    SET NOCOUNT ON;
    -- declare variables
    DECLARE @trancount CHAR(1) ,
            @XACT_STATE CHAR(1) ;
    -- fetch and print values at the beginning of the trigger
    SET @trancount =  @@TRANCOUNT ;
    SET @XACT_STATE  = XACT_STATE() ;
    PRINT '------------------------------------------------------------------------' ;
    PRINT 'When trigger starts @@trancount value is (' + @trancount + ' ).';
    PRINT 'When trigger starts XACT_STATE() return value is (' + @XACT_STATE + ' ).';
    -- ending the transaction inside the trigger
    COMMIT TRAN ;
    -- fetch and print values again
    PRINT 'After executing COMMIT statement, @@trancount value is (' + @trancount + ' ).';
    PRINT 'After executing COMMIT statement, XACT_STATE() return value is (' + @XACT_STATE + ' ).';
END ;
GO
-- test time!
INSERT dbo.Test ( Name )
  VALUES  ( N'somthing' ) ;
Figure 1
So, what is the Error Handling mechanism within Triggers?
Solution
There can be two types of solution
Classic Solution
This solution uses the second rule to rollback trigger and raise an error. The following code shows this mechanism:
GO
    NAME NVARCHAR(128)
GO
   ON  dbo.Test
   AFTER INSERT
AS
BEGIN
    SET NOCOUNT ON;
    IF 1 = 1
      BEGIN
        -- rollback and end the transaction inside the trigger
        ROLLBACK TRAN ;
        -- raise an error
        RAISERROR ( 'Error Message!', 16, 1) ;
      END
END ;
GO
-- test time!
Figure 2
Pitfall
This solution works fine until the RAISERROR is the last statement in trigger. If we have some statements after RAISERROR, they will execute as shown in next code:
GO
    NAME NVARCHAR(128)
GO
   ON  dbo.Test
   AFTER INSERT
AS
BEGIN
    SET NOCOUNT ON;
    IF 1 = 1
      BEGIN
        ROLLBACK TRAN ;
        -- raise an error
      END
      VALUES  ( N'extra' ) ;
END ;
GO
-- test time!
GO
SELECT *
FROM dbo.Test
Figure 3
Modern Solution
This solution is applicable to SQL Server 2012 and above versions. THROW statement enhances the error handling in triggers.  It rollback the statements and throw an error message. Next code shows this mechanism:
GO
    NAME NVARCHAR(128)
GO
   ON  dbo.Test
   AFTER INSERT
AS
BEGIN
    SET NOCOUNT ON;
    IF 1 = 1
      -- just throw!
      THROW 60000, 'Error Message!', 1 ;
END ;
GO
-- test time!
GO
SELECT *
FROM dbo.Test ;
Figure 4
As I explained in former article, introducing the THROW statement was a revolutionary movement in SQL Server 2012 Error Handling. This article proves it again, this time with triggers.
Other Languages
