The schemas can be extracted from the below steps.
The mapping XSLT can be extracted from the below steps.
Select the Map Class in the left panel, in the right panel, you can see the decompiled classes for the Map class you selected.
1) In your BizTalk, add a new map with the below name like below shown. Copy the name i.e. class name -> Replace Underscore with Dot ( _ to . ) - > Save file with BT.Map.btm BT_Map => BT.Map.btm
#if __DESIGNER_DATA
#error Do not define __DESIGNER_DATA.
XML Text Contents Goes Here
#endif // __DESIGNER_DATA
