  In the Below simple example, I am going to show how to get the basic four types of important data such as Excel Work Book Name, Worksheet Count in that Workbook, Name of the Worksheets, and finally the Value of the First Cell in that Worksheet.
Prerequisites
First step is to download the Openxml dll from the official site.
Second step is to kindly ensure to add the above dll, as shown in the screenshot, given below:
add
add
Important note
Once you load this dll and write the code, you will get the following error:
error
Resolution for above problem is,
dll
Add the above dll also to the project.
Namespace
  1. using DocumentFormat.OpenXml.Packaging;
  2. using DocumentFormat.OpenXml.Spreadsheet;
C# Code
  1. protected void insertBoqElements_Click(object sender, EventArgs e)
  2. {
  3.     try
  4.     {
  5.         //specify the file name where its actually exist
  6.         string filepath = @ "D:\TPMS\Uploaded_Boq\test.xlsx";
  7.
  8.         //open the excel using openxml sdk
  9.         using(SpreadsheetDocument doc = SpreadsheetDocument.Open(filepath, false))
  10.         {
  11.
  12.             //create the object for workbook part
  13.             WorkbookPart wbPart = doc.WorkbookPart;
  14.
  15.             //statement to get the count of the worksheet
  16.             int worksheetcount = doc.WorkbookPart.Workbook.Sheets.Count();
  17.
  18.             //statement to get the sheet object
  19.             Sheet mysheet = (Sheet) doc.WorkbookPart.Workbook.Sheets.ChildElements.GetItem(0);
  20.
  21.             //statement to get the worksheet object by using the sheet id
  22.             Worksheet Worksheet = ((WorksheetPart) wbPart.GetPartById(mysheet.Id)).Worksheet;
  23.
  24.             //Note: worksheet has 8 children and the first child[1] = sheetviewdimension,....child[4]=sheetdata
  25.             int wkschildno = 4;
  26.
  27.
  28.             //statement to get the sheetdata which contains the rows and cell in table
  29.             SheetData Rows = (SheetData) Worksheet.ChildElements.GetItem(wkschildno);
  30.
  31.
  32.             //getting the row as per the specified index of getitem method
  33.             Row currentrow = (Row) Rows.ChildElements.GetItem(1);
  34.
  35.             //getting the cell as per the specified index of getitem method
  36.             Cell currentcell = (Cell) currentrow.ChildElements.GetItem(1);
  37.
  38.             //statement to take the integer value
  39.             string currentcellvalue = currentcell.InnerText;
  40.
  41.         }
  42.     } catch (Exception Ex)
  43.     {
  44.
  45.         lbldisplayerrors.Text = Ex.Message;
  46.     }
  47.
  48. }
Note
If the cell contains a string, then this value is an index into the shared string table, pointing to the actual string value. Otherwise, the value of the cell is expressed directly in this element
Source: CellValue Class
For taking the string Value from Cell
  2. {
  3.     try
  4.     {
  7.
  10.         {
  11.
  14.
  17.
  20.
  23.
  26.
  27.
  30.
  31.
  33.             Row currentrow = (Row) Rows.ChildElements.GetItem(0);
  34.
  36.             Cell currentcell = (Cell) currentrow.ChildElements.GetItem(0);
  37.
  38.             string currentcellvalue = string.Empty;
  39.
  40.
  41.             if (currentcell.DataType != null)
  42.             {
  43.                 if (currentcell.DataType == CellValues.SharedString)
  44.                 {
  45.                     int id = -1;
  46.
  47.                     if (Int32.TryParse(currentcell.InnerText, out id))
  48.                     {
  49.                         SharedStringItem item = GetSharedStringItemById(wbPart, id);
  50.
  51.                         if (item.Text != null)
  52.                         {
  53.                             //code to take the string value
  54.                             currentcellvalue = item.Text.Text;
  55.                         } else if (item.InnerText != null)
  56.                         {
  57.                             currentcellvalue = item.InnerText;
  58.                         } else if (item.InnerXml != null)
  59.                         {
  60.                             currentcellvalue = item.InnerXml;
  61.                         }
  62.                     }
  63.                 }
  64.             }
  65.
  66.         }
  67.     } catch (Exception Ex)
  68.     {
  69.
  70.         lbldisplayerrors.Text = Ex.Message;
  71.     }
  72.
  73. }
  74.
  75. public static SharedStringItem GetSharedStringItemById(WorkbookPart workbookPart, int id)
  76. {
  77.     return workbookPart.SharedStringTablePart.SharedStringTable.Elements < SharedStringItem > ().ElementAt(id);
  78. }
Other References
Link to:
 Read excel files using Microsoft Office Interop Assemblies in asp.net
Downloads:
you can download the executable in from here : https://gallery.technet.microsoft.com/OpenXMLSimpleExample-a757f10c
hope the above information was useful. Kindly let me know your thoughts.
