This sample is for File.CopyFile, File.DeleteFile and File.GetFiles.
Code
' Small DOS - Sample Code for File.CopyFile, File.DeleteFile and File.GetFiles
' Version 0.1
' Program ID TJK128
TextWindow.WriteLine("Small DOS Version 0.1")
TextWindow.WriteLine("")
Init()
While "True"
  TextWindow.Write(path + ">")
  cmdLine = TextWindow.Read()
  GetArg()
  If cmd = "DIR" Then
    files = File.GetFiles(path)
    ShowFiles()
  ElseIf cmd = "COPY" Then
    err = File.CopyFile(path + "\" + file1, path + "\" + file2)
    ShowError()
  ElseIf cmd = "DEL" Then
    err = File.DeleteFile(path + "\" + file1)
    ShowError()
  ElseIf cmd = "TYPE" Then
    ShowFile()
  ElseIf cmd = "EXIT" Then
    Program.End()
  Else
    TextWindow.WriteLine("COPY <file1> <file2>")
    TextWindow.WriteLine(" Copy <file1> as <file2>.")
    TextWindow.WriteLine("DEL <file>")
    TextWindow.WriteLine(" Delete <file>.")
    TextWindow.WriteLine("DIR")
    TextWindow.WriteLine(" Show filenames in the directory.")
    TextWindow.WriteLine("EXIT")
    TextWindow.WriteLine(" Exit from Small DOS.")
    TextWindow.WriteLine("TYPE <file>")
    TextWindow.WriteLine(" Show <file>.")
  EndIf
EndWhile
Sub Init
  CRLF = Text.GetCharacter(13) + Text.GetCharacter(10)
  Not = "True=False;False=True;"
  path = Program.Directory
  space = " "
EndSub
Sub GetArg
  ' param cmdLine - command line
  ' return cmd - command
  ' return file1, file2 - arguments
  p = 1
  len = Text.GetLength(cmdLine)
  SkipSpace()
  GetToken()
  cmd = Text.ConvertToUpperCase(Token)
  SkipSpace()
  GetToken()
  file1 = Token
  SkipSpace()
  GetToken()
  file2 = Token
EndSub
Sub SkipSpace
  ' param p - current pointer to command line
  ' param len - command line length
  c = Text.GetSubText(cmdLine, p, 1)
  While Text.IsSubText(space, c) And p <= len
    p = p + 1
  EndWhile
EndSub
Sub GetToken
  ' return token
  Token = ""
  While Not[Text.IsSubText(space, c)] And p <= len
    p = p + 1
    Token = Text.Append(Token, c)
  EndWhile
EndSub
Sub ShowError
  ' param err - "FAILED" if error
  If err = "FAILED" Then
    TextWindow.ForegroundColor = "Red"
    TextWIndow.WriteLine(File.LastError)
    TextWindow.ForegroundColor = "Gray"
  EndIf
EndSub
Sub ShowFile
  ' param file1 - to show
  buf = File.ReadContents(path + "\" + file1)
  p = 1
  len = Text.GetLength(buf)
  While p <= len
    eol = Text.GetIndexOf(Text.GetSubTextToEnd(buf, p), CRLF)
    If 0 < eol Then
      line = Text.GetSubText(buf, p, eol + 1)
      p = p + eol + 1
    Else
      line = Text.GetSubTextToEnd(buf, p)
      p = len + 1
    EndIf
    TextWindow.Write(line)
  EndWhile
EndSub
Sub ShowFiles
  ' param files - files array
  If files = "FAILED" Then
    ShowError()
  Else
    n = Array.GetItemCount(files)
    len = Text.GetLength(path + "\")
    For i = 1 To n
      TextWindow.WriteLine(Text.GetSubTextToEnd(files[i], len + 1))
    EndFor
  EndIf
EndSub
