Issue
When installing MIM Synchronization Service you get this error:
Product: Microsoft Identity Manager Synchronization Service -- Error 25009. The Microsoft Identity Manager Synchronization Service setup wizard cannot configure the specified database. <hr=0x80131700>
References
This Wiki article is based on forum threads reporting the issue mentioned above like:
Solution
SA Admin rights
Check: FIM Troubleshooting: Installation Error 25009 (SA admin rights missing)
SQL 2012 Native client
MIM requires a recent SQL native client, matching the SQL version.
For SQL Server 2014
https://msdn.microsoft.com/en-us/library/ms131321(v=sql.120).aspx
Microsoft SQL Server Native Client 11.0 is installed when you install SQL Server 2014. There is no SQL Server 2014 Native Client.”
You can also get sqlncli.msi from the SQL Server 2012 Feature Pack web page. To download the most recent version of the SQL Server Native Client, go to Microsoft® SQL Server® 2012 SP2 Feature Pack. If a previous version of the SQL Server Native Client earlier than SQL Server 2012 is also installed on the computer.
.Net Framework 3.5
MIM 2016 must have .NET Framework 3.5 installed from the Windows server features.
See: https://technet.microsoft.com/en-us/library/hh332708%28v=ws.10%29.aspx
References
See also
