Here we will discuss how we can check for errors or issues in Microsoft Flow. If you are new to Microsoft flow then you can check below articles.
- Working with Microsoft Flow in SharePoint Online Office 365 and Demo on Send a customized email when a new SharePoint list item is added
- Microsoft Flow Tutorials and Save my email attachments to a SharePoint document library Flow Sample
- Microsoft Flow Send approval email when a new item is added demo
Microsoft flow is a new workflow management tool for automating workflows across applications and services by connecting web services, files, and cloud-based data. We can connect with various services like SharePoint, Office 365, OneDrive, Twitter, Facebook, Dropbox, Outlook, Instagram, Outlook, Yammer, Excel, Google Calendar etc.
To check if any issues are there or not we have to first login to Microsoft Flow site.
In the flow site in notification it will display you if any errors are there like below:
Or you can click on My flows button which will display you about all the flows that you have created. There click on the information icon for the particular workflow for which you want to check like below:
Then it will show each with Status as Failed or Succeeded like below. Click on the Failed item to see details about the issue.
Then it will display in which step the error has been occurred with red explanation mark. For steps which are successful it will display tick mark in green color.
Once you click on it it will display the error details.
Hope this will be helpful.
