Table of Contents
Preface
In this chapter we want  to Calculate Body Mass Index (BMI).
Process
The following steps show how Calculate Body Mass Index (BMI):
  1. First, Click New Project in Start Page or On File Menu.
  2. In New Project Dialog , Click Windows On Left Pane And Windows Forms Application On Middle Pane.
  3. Change form layout to this Mode:
4.Add these Items To ComboBox :
  • 19 to 24
  • 25 to 34
  • 35 to 44
  • 45 to 54
  • 55 to 64
  • More Than 65
5.Set BMI Textbox Enable To False.
6.We Know The BMI  Is Mass(Kg) / (height(m))2.Then Into Click Event Of Calculate Your BMI Button Write This Code :
double bmi;
 double vazn = double.Parse(numericUpDown2.Value.ToString());
 double ghad2 = Math.Pow(double.Parse(numericUpDown1.Value.ToString()), 2);
 bmi = vazn / ghad2;
 if (bmi.ToString().Length > 5)
 textBox1.Text = (vazn / ghad2).ToString().Remove(5);
 else
 textBox1.Text = (vazn / ghad2).ToString();
 if (bmi < 16.5 && bmi > 11)
 label15.Visible = true;
 label16.Visible = false;
 label17.Visible = false;
 label18.Visible = false;
 label19.Visible = false;
 else if (bmi < 18.5 && bmi > 16.5)
  label15.Visible = false;
  label16.Visible = true;
  else if (bmi < 25 && bmi > 18.5)
  label17.Visible = true;
  else if (bmi < 30 && bmi > 25)
  label18.Visible = true;
  else if (bmi > 30)
7.For Show Appropriate BMI , Into The SelectedIndexChanged Event Of Age Range ComboBox , Write This Code :
if (comboBox1.SelectedIndex == 0)
 label14.Text = "22";
 else if (comboBox1.SelectedIndex == 1)
 label14.Text = "23";
 else if (comboBox1.SelectedIndex == 2)
 label14.Text = "24";
 else if (comboBox1.SelectedIndex == 3)
 label14.Text = "25";
 else if (comboBox1.SelectedIndex == 4)
 label14.Text = "26";
 else if (comboBox1.SelectedIndex == 5)
 label14.Text = "27";
