Visual studio code and asp.net core MVC
Today, I am going to talk about implementing asp.net core in visual studio code.
VS code is a lightweight tool compared to visual studio. It runs fast, is easy to use and with the extensions you can improve your development setup.
Setup
What do we need?
  • vs code (https://code.visualstudio.com/)
  • .net core 2.0 sdk
Install the vs code on your computer and follow the .net core setup instructions.
Once dotnet core is installed open command prompt and type :
dotnet -h
you should get an output of dotnet.
Next open visual studio and go to extensions and search for "the C# extension" and download it.
If you prefer you can install the visual studio keymap, if you like the shortcuts of visual studio.
create a new project folder for example C:\myApp
Create an asp.net core mvc app
  • Open in visual code your project folder (myApp).
  • Go to view "integrated terminal" and type dotnet new web.
  • dotnet will install an empty web project the folders will be displayed in vs code.
Next, add two folders Controllers and Views.
In the "Views"folder create a sub-folder called Home.
And an Index.cshtml with the text hello world in  Views/Home.
<h1>hello world</h1>
In the "Controllers" folder add a homecontroller.cs
using Microsoft.AspNetCore.Mvc;
namespace myapp.Controllers{
    public class HomeController:Controller{
        public IActionResult Index(){
            return View();
Next, we have to configure the project so it can use mvc.
Open the startup.cs file and add the following code
using System;
using System.Linq;
using System.Threading.Tasks;
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.AspNetCore.Http;
using Microsoft.Extensions.DependencyInjection;
namespace myapp
    public class Startup
        // This method gets called by the runtime. Use this method to add services to the container.
        // For more information on how to configure your application, visit https://go.microsoft.com/fwlink/?LinkID=398940
        public void ConfigureServices(IServiceCollection services)
            services.AddMvc();
        // This method gets called by the runtime. Use this method to configure the HTTP request pipeline.
        public void Configure(IApplicationBuilder app, IHostingEnvironment env)
            app.UseStaticFiles();
            app.UseMvc(routes =>
                routes.MapRoute(
                    template: "{controller=Home}/{action=Index}/{id?}");
We configured the mvc routing so that it will look for the HomeController with the action method Index when the app runs.
The index method corresponds with the Views/Home/Index.cshtml view in
We're ready, hit the start debugging button in the "debugging tab" or type
dotnet run
the app will run and you will see the "hello world" text.
References
The whole article is on my blog with more details
  • http://thecodebro.blogspot.be/2017/08/aspnet-core-20-mvc-from-stratch-in-vs.html
Back to Top
