Principles and Goals of Universal Windows Plateforms (UWP), Xamarin and TypeScript :
From Framework 3.5 to version 4, we were able to create Windows Presentation Framework (WPF) -based applications primarily for heavy office-type client solutions.
But later from the Visual Studio 2015 development environments and Xamarin Studio, new types of applications have been realized among others UWP (Universal Windows Platforms) applications, this type of application support many more platforms and can be extended to other thin client-oriented languages ​​like JavaScript.
It is now possible from the C # / XAML and JavaScript languages ​​to create mutliplatform applications called UWP.
To fully understand the mechanism, with these 2 types of technologies (XAML and JavaScript) can create applications
on SmartPhones and touch tablets: Windows Phone 10, Android, IoS and even Linux.
And those for phone and tablet supporting the Android system as brands Samsung, Apple and more than a hundred manufacturers running on Android versions 2.1 to 8.0.0 with different distributions like Android Marshmallow or Nougat.
Similarly with these new types of applications have the possibility with UWP to create Internet Of Things (IoT) projects on
 micro motherboards in embedded as Raspberry PI or Qualcomm DragonBoard.
Regarding the different types of Xamarin and TypeScript applications: there are 2 categories :
Native Applications: write in manufacturer language and recognized directly by the terminal system :
Example:     App written in Objective-C for Apple IoS.
                   App written in Java for Android systems.
                   App written in C # for Microsoft systems.
Then the non-native applications written in Web supported on all the platforms :
App written in JavaScript compatible on Microsoft, Apple and Android systems.
This accounting is provided by the web browser of the mobile terminal browser.
This is the case thanks to the interpreter of the Apache web browser with among other applications written from
Apache Cordova technology that allows since JavaScript to create multiplatform apps regardless of the builders: it is the interoperability of the platforms.
TypeScript is a free and open source programming language developed by Microsoft that aims to improve and secure the production of JavaScript code. This is a superset of JavaScript
 (that is, any valid JavaScript can be used with TypeScript). The TypeScript code is transcompiled in JavaScript, which can be interpreted by any web browser or JavaScript engine. He was co-created by Anders Hejlsberg, the main inventor of C # 1,2,3,4,5.
TypeScript allows optional static typing of variables and functions, creating classes and interfaces, importing modules, while maintaining the non-binding approach of JavaScript. It supports the ECMAScript 6 specification.
More than 10 years ago this goal of interoperability of the platforms was the goal of the Java language now it is ensured since
the JavaScript thin client language.
If this cross-platform compatibility is provided with JavaScript for non-native applications.
So we could say what's the point of continuing to develop with native language or even heavy client-oriented code
as Objective-C or C # / XAML?
This multi-platform accounting is assured among other things with C # / XAML or any other heavy client language
thanks to the Xamarin platform.
To fully understand what Xamarin is, initially it was the Mono Project to make applications compatible
Windows and Linux together. Then Mono became the Moonlight project initiated by the Microsoft community.
Moonlight has given birth to the Xamarin project, which has made it possible since any language to write multiplatform applications.
Since C # / XAML, we can native applications for Windows Mobile, Android and IoS Apple.
Similarly since Mac OS, we can create multiplatform applications.
TypeScript is used to create Non-Native applications based on JavaScript.
Xamarin is used tp create Native applications based on heavy client-orented code.
The Same Job with Xamarin.Net and Apache Cordova : only difference Native and
No-Native plateform but Cross-Plateform.
Sample of creation of Cross-plateform project with Xamarin (C#/XAML)
Sample of creation of Cross-plateform project with Apache Cordova (TypeScript)
Choose a Empty Application or Application based on Master-Details
Choose an UWP target Plateform for your solution : a Windows 10 specific build version
Which version of target platform to choose? it depends on the version of your operating system and therefore different updates.
You will find this information in the system settings of your PC, however it is recommended to update your computer regularly to
 have the most stable version possible including the latest patches and improvements.
In Your System settings configuration page : you can see here the last version updated of Windows 10 : version 15063.
After choosing the latest updated version of Platform Update Creator 15063, your solution is created from
UWP cross-platform project model, Android and IoS.
You can see on the Top of the solution, a Shared project that contains the shared source code between all
the differents plateforms.
A sample of Android project write with C#/XAML used Xamarin plateform :
in this complete sample, you can see the creation of Google App with Xamarin tools.
The main assembly use to develop with Xamarin is Mono.Android.
For a Cross-Plateform project is Xamarin.Forms, for understand in the past Xamarin was Mono project
but it's the same behaviour to develop.
In an Android project, you have the main entry point or main class of the MainActivity project in
C # is the MainActivity.cs file.
This class derives from the MainActivity base class and must override the OnCreate (Bundle) method.
It features MainActivity attribute tags with different Label, MainLauncher, and Icon options.
Always think of calling the SetContentView method which allows to attach to our class the display page defined in the
Project resources, here accessible from Resource.Layout namely the Hand written graphic resource in XAML.
    [Activity (Label = "com.genuisoft.genuisradioandtv", MainLauncher = true, Icon = "@ drawable / icon")]
    public class MainActivity: Activity
        protected override void OnCreate (bundle bundle)
            base.OnCreate (bundle);
            // Set our view from the "main" layout resource
            SetContentView (Resource.Layout.Main);
Regarding the second important part in this type of project: graphic resources.
They are broken down into 3 subdirectories found in Resources: drawable, layout and values.
Drawable: will contain the graphic resources types images: png, jpg or ico as well as XML graphic resource files
to customize components of the HMI.
This is a sample of XML customization of graphical component, here a button template :
<?xml version="1.0" encoding="utf-8"?>
<selector xmlns:android="http://schemas.android.com/apk/res/android">
  <item android:state_pressed="true" >
    <shape>
      <solid
          android:color="#85530F" />
      <stroke
          android:width="1dp"
      <corners
          android:radius="6dp" />
      <padding
          android:left="3dp"
          android:top="3dp"
          android:right="3dp"
          android:bottom="3dp" />
    </shape>
  </item>
  <item>
    <shape>
      <gradient
          android:startColor="#85530F"
          android:endColor="#85530F"
          android:angle="270" />
      <stroke
          android:width="1dp"
          android:color="#5A3A22" />
      <corners
          android:radius="25dp" />
      <padding
          android:left="2dp"
          android:top="2dp"
          android:right="2dp"
          android:bottom="2dp" />
    </shape>
  </item>
</selector>
On the Values folder, you are the text resource of your application like this :
Contains on the Strings.xml
<resources>
    <string name="Hello">Hello World, Click Me!</string>
    <string name="ApplicationName">Genuis News Speech</string>
</resources>
On the Style.xml file, you are by exemple this resource content :
<?xml version="1.0" encoding="utf-8" ?>
<resources>
  <string name="planet_prompt">Choose a language</string>
  <string-array name="country_array">
    <item>English</item>
    <item>Italian</item>
    <item>French</item>
    <item>German</item>
  </string-array>
  <style name="buttontext">
    <item name="android:layout_width">fill_parent</item>
    <item name="android:layout_height">wrap_content</item>
    <item name="android:textColor">#000000</item>
    <item name="android:background">@drawable/micro</item>
    <item name="android:gravity">center</item>
    <item name="android:layout_margin">3dp</item>
    <item name="android:textSize">5dp</item>
    <item name="android:textStyle">bold</item>
    <item name="android:shadowColor">#000000</item>
    <item name="android:shadowDx">1</item>
    <item name="android:shadowDy">1</item>
    <item name="android:shadowRadius">5</item>
  </style>
  <style name="edittext">
    <item name="android:textColor">#ffffff</item>
  </style>
</resources>
Now let's focus on the Main.axml graphic interface page.
For the axml extension instead of xaml, the Xaml language is well used in this graphic file
but this axml extension is recognized by Android systems.
This file is content on the Layout folder of your project.
It's required to use the namespace http://schemas.android.com/apk/res/android.
This namespace defined the XML langage structure of your graphical file.
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:orientation="vertical"
    android:theme="@android:style/Theme.Black.NoTitleBar"
    android:background="@drawable/wallpaper"
    android:layout_width="match_parent"
    android:id="@+id/stackView1"
    android:layout_height="match_parent">
    <ImageView
        android:id="@+id/img"
        android:src="@drawable/speech"
        android:layout_gravity="center_vertical|center_horizontal"
        android:layout_width="50dp"
        android:layout_height="50dp" />
    <EditText
        android:id="@+id/txtitle"
        android:editable="false"
        android:textSize="14dp"
        android:foreground="@android:color/holo_purple"
        android:textColor="@android:color/holo_purple"
        android:textStyle="bold"
        android:layout_marginStart="5dp"
        android:layout_marginEnd="5dp"
        android:layout_marginTop="5dp"
        android:layout_marginBottom="5dp"
        android:backgroundTint="#fff0ffff"
        android:background="@android:color/holo_green_light" />
    <Spinner
        android:id="@+id/comboboxlang"
        android:prompt="@string/planet_prompt"
        android:background="@android:color/black"
        android:foreground="@android:color/white"
    <WebView
        android:id="@+id/imagecenter"
        android:layout_height="220dp"
        android:paddingStart="5dp"
        android:paddingEnd="5dp"
        android:paddingTop="5dp"
        android:paddingBottom="5dp"
        android:paddingRight="4dp"
        android:paddingLeft="5dp" />
    <Button
        android:id="@+id/buttonlisten"
        android:textSize="18dp"
        android:background="@drawable/micro"
        android:onClick="buttonlistenclick"
        android:layout_height="70dp"
        android:layout_width="70dp" />
    <Button
        android:id="@+id/buttonstop"
        android:text="Stop"
        android:background="@drawable/bluebutton"
        android:onClick="buttonstopclick"
</LinearLayout>
The most important property for any component are
android:id with an index increment for the component identifier and many other
parameters like textSize, textStyle,text, background.
You need to respect the naming specific to Java langage : all keyword are called
on the android namespace and the property name begin on lowercase and highercase
between the word.
Java language and XAML coexists in our development.
In this sample source code, you'll see how to handle interactions between Android graphics
and C # source code.
On a Button component, you have the android method: onclick, you assign it the
textlistlistenclick property.
 <Button
                    android: id = "@ + id / buttonplay"
                    android: textSize = "14dp"
                    android: TextStyle = "bold"
                    android: background = "@ drawable / play"
                    android: onclick = "buttonlistenclick"
                    android: foreground = "@ android: color / white"
                    android: layout_gravity = "center_vertical | center_horizontal"
                    android: layout_height = "80dp"
                    android: layout_width = "80dp"
                    android: layout_marginTop = "5DP"
                    android: layout_marginBottom = "5DP"
                    android: paddingStart = "5DP"
                    android: paddingEnd = "5DP"
                    android: paddingTop = "5DP"
                    android: textColor = "@ android: color / background_light"
                    android: layout_marginRight = "5DP"
                    android: layout_marginStart = "5DP"
                    android: layout_marginEnd = "5DP"
                    android: layout_marginLeft = "5dp" />
In the MainActivity.cs file, you need to attach the declare event buttonlistenclick
on a delegate method like this :
        [Export("buttonstopclick")]
        public void buttonStopClick(View v)
            if (mediaPlayer == null)
                return;
            if (mediaPlayer.IsPlaying)
                mediaPlayer.Stop();
The most important in this sample is the Tag attribute Export, it's permit to bind
the action method buttonStopClick(View v) to the Android componant Button.
To call an instance of a graphical component, you need to use the method FindViewById<T>(resourceId)
with a generic type.
SeekBar _seekBar = FindViewById<SeekBar>(Resource.Id.seekBar1);
or
Button _buttonPlay = FindViewById<Button>(Resource.Id.buttonPlay);
Of more you are the possibility to implemented many graphical behaviour
with :MediaPlayer.IOnPreparedListener, ISurfaceHolderCallback, SeekBar.IOnSeekBarChangeListener.
MediaPlayer.IOnPreparedListener : use for a MediaPlayer component interactions with the method OnPrepared(MediaPlayer player).
ISurfaceHolderCallback : use to manage the tactile interactions.
 Definition of the Interface to interact with the tactile screen :
    [Register("android/view/SurfaceHolder$Callback", "", "Android.Views.ISurfaceHolderCallbackInvoker", ApiSince = 1)]
    public interface ISurfaceHolderCallback : IJavaObject, IDisposable
        [Register("surfaceChanged", "(Landroid/view/SurfaceHolder;III)V", "GetSurfaceChanged_Landroid_view_SurfaceHolder_IIIHandler:Android.Views.ISurfaceHolderCallbackInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
        void SurfaceChanged(ISurfaceHolder holder, [GeneratedEnum] Format format, int width, int height);
        [Register("surfaceCreated", "(Landroid/view/SurfaceHolder;)V", "GetSurfaceCreated_Landroid_view_SurfaceHolder_Handler:Android.Views.ISurfaceHolderCallbackInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
        void SurfaceCreated(ISurfaceHolder holder);
        [Register("surfaceDestroyed", "(Landroid/view/SurfaceHolder;)V", "GetSurfaceDestroyed_Landroid_view_SurfaceHolder_Handler:Android.Views.ISurfaceHolderCallbackInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
        void SurfaceDestroyed(ISurfaceHolder holder);
SeekBar.IOnSeekBarChangeListener : to manage the interactions between the user and a seekbar component.
          public interface IOnSeekBarChangeListener : IJavaObject, IDisposable
            [Register("onProgressChanged", "(Landroid/widget/SeekBar;IZ)V", "GetOnProgressChanged_Landroid_widget_SeekBar_IZHandler:Android.Widget.SeekBar/IOnSeekBarChangeListenerInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
            void OnProgressChanged(SeekBar seekBar, int progress, bool fromUser);
            [Register("onStartTrackingTouch", "(Landroid/widget/SeekBar;)V", "GetOnStartTrackingTouch_Landroid_widget_SeekBar_Handler:Android.Widget.SeekBar/IOnSeekBarChangeListenerInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
            void OnStartTrackingTouch(SeekBar seekBar);
            [Register("onStopTrackingTouch", "(Landroid/widget/SeekBar;)V", "GetOnStopTrackingTouch_Landroid_widget_SeekBar_Handler:Android.Widget.SeekBar/IOnSeekBarChangeListenerInvoker, Mono.Android, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null")]
            void OnStopTrackingTouch(SeekBar seekBar);
Configuring and Deployment :
Regarding the mobile deployment platform, we will try to deploy our solution
on a Samung Galaxy S7 running with the Android 7.0 Nougat operating system.
You must have a file in your solution called package.config which
the structure and the content should look like this:
<? xml version = "1.0" encoding = "utf-8"?>
<Package>
  <package id = "Xamarin.Android.Support.Annotations" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.Compat" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.Core.UI" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.Core.Utils" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.Fragment" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.Media.Compat" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Android.Support.v4" version = "25.4.0.2" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Build.Download" version = "0.4.7" targetFramework = "monoandroid70" />
  <package id = "Xamarin.Google.iOS.MobileAds" version = "7.19.0" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Ads" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Ads.Lite" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Base" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Basement" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Clearcut" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Gass" version = "42.1021.1" targetFramework = "monoandroid70" />
  <package id = "Xamarin.GooglePlayServices.Tasks" version = "42.1021.1" targetFramework = "monoandroid70" />
</ Packages>
Use the Android SDK Manager to install all required packages for your deployment :
For exemple, for a deployment in a Samsung Galaxy S7 with Android Nougat 7.0 need to use the API Level 24 but for a most recent version of Android Operating system, probably need to use the API Level 27 for Android 8.0.
And another important file of configuration, AndroidManifest.xml like this :
this Xml file content the Android namespace, the package name, the code version of deployement.
Of more the different rights need to use in your application.
<manifest xmlns:android="http://schemas.android.com/apk/res/android" package="com.genuis.genuisradiotvwave" android:versionCode="3" android:versionName="1.0" android:installLocation="preferExternal">
<uses-sdk android:minSdkVersion="14" />
<uses-permission android:name="android.permission.INTERNET" />
<application android:allowBackup="true" android:label="Genuis Radio TV" android:icon="@drawable/Icon"></application>
</manifest>
To test a deployment of your Project, 2 options :
 - Use an an Physical external device like a SmartPhone with Android Operating System.
 - Use a Virtual Device with an Android device emulator.
In the second option, you need to create and install an emulate device with
the Android Virtual Device monitor called AVD Manager.
Another Tool very practice, the Adb Console, this command prompt permit to have a shell for configure the compilation and the deployment of your project.
For exemple, if your an error of deployment then you need to restart the Adb server.
Instruction to restart your Adb server :
adb kill-server
adb start-server
To Debug and deploy on your Android smartphone like Samsung Galaxy S7,
you need to activate the USB debugging option mode on your phone settings.
Once your project is developed and the binaries generated by compilation, you need to create Deployment Packages, which are similar archives in Java to .jar archives.
Except for an Android project, these archives are packages signed Apk.
After your Apk signed package generated, you need to distribute your App with 2 ways :
Ad Hoc or Google Play.
In this step, you need to create Certificate file for your package with all editor informations and a password for encrypted your solution :
it's mecanism to protect your source code creation.
When your signed package are create and ready to by distributed, you are the possibility to use a
Google Play account to publish your application on the Google Store or another way of distribution.
For the Google Play store, you need to create a valid developer account with the Google Play Console
web page : but this step it's just a bonus remark for Google developer.
This page on Google Play Console is very interesting because it shows the number of devices listed compatible with our application,
we can notice a large number of devices on the market where
our Android application can run up to more than 15,481 devices !
About Xamarin project for Apple IoS for IPhone / Ipad device
Note about Xamarin projects oriented IoS, to create this type of project there is no emulator
IoS type IPhone or IPad compatible with the Microsoft architecture.
To realize this type of project and to be able to compile them, you will have to use a Mac OS application server
like for example a Macintosh paired with your PC, once the pairing done between your 2 computers,
Visual Studio will be able to use your Macintosh as an application server for debugging and then you can
emulate an Iphone or Ipad deployment: but here again we have a specifity specific to the differences of
architecture between
Windows and Macintosh.
Sample Application deploy on a Samsung Galaxy 7 with Android Nougat 7.0
Visit my Portfolio Website : www.genuisoft.com
Daniel Padrosa
Software Engineer senior
Microsoft Certified Professional
Microsoft Professional Associate
Microsoft Certified Technology Specialist
Microsoft Certified Professional Developer
