Background
Do you find yourself writing a handful of codes to execute a single or number of SQL statement(s) in your C# program using System.Data.SqlClient?
Do your code somewhat looks like this as follows:
SqlConnection conn = new SqlConnection(SQLConnectionString);
SqlCommand comm = null;
int returnResult;
try
    comm = conn.CreateCommand();
    comm.CommandType = CommandType.Text;
    comm.CommandText = Query;
    comm.CommandTimeout = SQLTimeout;
        try
            conn.Open();
            returnResult = comm.ExecuteNonQuery();
        catch
            conn.Close();
            throw new SqlException();
catch (Exception ex)
    throw new Exception(ex.Message.ToString());
finally
    conn.Close(); // Always remember to close connection to database or else it would lead to memory leakage
And don't even mention that what a headache this code can cause to you in case you mess up or forget a single line of code from the above.
But do not worry, there is an easy solution.
Enters The EasySQL Class
Use EasySQL class library to execute any (or list of) SQL statement(s) without hassle.
Let me show you how you can write the aforementioned code using EasySQL Class as follows:
EasySQL thisSQL = new EasySQL(SQLConnectionString);
thisSQL.Execute(Query);
That's it. Nothing else. You don't have to worry about opening or closing database connections or worry about other small stuff so that you can devote more in developing your solution effectively rather than fighting to execute database queries.
EasySQL is downloadable and installable from Nuget Package Explorerhttps://www.nuget.org/packages/EasySQL2/ under the package name: EasySQL2
PM>Install-Package EasySQL2 -Version 1.0.0.1
Methods In EasySQL Class
Name Returns Description
IsConnected() bool Returns true or false whether connection to database is successful or not
GetConnectionString() String Returns the connection string which is set/used
GetTimeout() Int Returns the connection timeout
Execute(String) Int Executes the query and returns the number of rows affected
Execute(String, out DataSet) Int Executes the query to fetch the data in dataset and returns the number of rows affected
Execute(String, out DataTable) Int Executes the query to fetch the data in data table and returns the number of rows affected
ExecuteProcedure(String) Int Excutes the stored procedure and returns the number of rows affected
ExecuteProcedure(String, out DataSet) Int Excutes the stored procedure to fetch data in dataset and returns the number of rows affected
ExecuteProcedure(String, out DataTable) Int Excutes the stored procedure to fetch data in data table and returns the number of rows affected
Execute(String, SqlCredential) Int Executes the query using SqlCredential for elevated security and returns the number of rows affected
Execute(String, SqlCredential, out DataSet) Int Executes the query using SqlCredential for elevated security to fetch the data in dataset and returns the number of rows affected
Execute(String, SqlCredential, out DataTable) Int Executes the query using SqlCredential for elevated security to fetch the data in datatable and returns the number of rows affected
ExecuteProcedure(String, SqlCredential) Int Executes the stored procedure using SqlCredential for elevated security and returns the number of rows affected
ExecuteProcedure(String, SqlCredential, out DataSet) Int Executes the stored procedure using SqlCredential for elevated security to fetch data in dataset and returns the number of rows affected
ExecuteProcedure(String, SqlCredential, out DataTable) Int Executes the stored procedure using SqlCredential for elevated security to fetch data in datatable and returns the number of rows affected
Execute(String, Dictionary<String, String>) Int           Executes the query along with parameters and returns the number of rows affected
Execute(String, Dictionary<String, String>, out DataSet) Int Executes the query  along with parameters to fetch the data in dataset and returns the number of rows affected
Execute(String, Dictionary<String, String>, out DataTable) Int Executes the query along with parameters  to fetch the data in data table and returns the number of rows affected
Execute(String, Dictionary<String, String>SqlCredential) Int Executes the query along with parameters using SqlCredential for elevated security and returns the number of rows affected
Execute(String, Dictionary<String, String>SqlCredential, out DataSet) Int Executes the query along with parameters using SqlCredential for elevated security to fetch the data in dataset and returns the number of rows affected
Execute(String, Dictionary<String, String>SqlCredential, out DataTable) Int Executes the query along with parameters using SqlCredential for elevated security to fetch the data in datatable and returns the number of rows affected
Some Examples
Let's insert a new record of city in our CITIES table as follows:
private void InsertCityRecord(string connectionString)
  string query = "Insert Into [CITIES] (CityName, Country) VALUES('Kolkata', 'India')";
  EasySQL thisSQL = new EasySQL(connectionString);
  thisSQL.Execute(query);
Or we can fetch user credentials from a form and use that to query our database as follows:
private void runUserQuery()
  // Fetch User input
  System.Windows.Controls.TextBox txtUserId = new System.Windows.Controls.TextBox();
  System.Windows.Controls.PasswordBox txtPwd = new System.Windows.Controls.PasswordBox();
  // Read config for connection string
  Configuration config = Configuration.WebConfigurationManager.OpenWebConfiguration(Null);
  ConnectionStringSettings connString = config.ConnectionStrings.ConnectionString[“MyConnString”];
  // Create sql credential
  SecureString pwd = txtPwd.SecurePassword;
  pwd.MakeReadOnly();
  SqlCredential cred = new SqlCredential(txtUserId.Text, pwd);
  // Execute using EasySQL
  EasySQL thisSQL = new EasySQL(connString);
  thisSQL.ExecuteProcedure(storedProcedureName, cred);
Or we can also execute a list of queries as follows:
private void runListOfQueries(List<string> queries, string connectionString)
  // Initiate EasySQL
  // Iterate over list of queries and execute one by one
  foreach(string query in queries)
Extras
The source code of the EasySQL Class library is available to download from TechNet Gallery and GitHub.
