In this article, we will show you how to create an IoT Hub and connect your IoT Device.
Pre-requisites
  • Required Hardware:
    • Windows 10 PC
    • IoT Hardware kit: https://www.adafruit.com/product/3605 or similar hardware.
    • Access to a WiFi network
  • Required Operating System:
    • Windows 10
  • Other Requirements:
    • Azure Subscription
  • Required Software:
    •  IoT Device Explorer, download: https://github.com/Azure/azure-iot-sdk-csharp/releases/download/2017-1023/SetupDeviceExplorer.msi
Steps:
Verify you properly setup your IoT Device Connectivity
please refer to https://learn.adafruit.com/adafruit-feather-huzzah-esp8266/using-arduino-ide
Create an IoT Hub
Now you will create an IoT Hub in the Azure Portal. Go to the Azure Portal, click Create new and type “iot hub”:
Create IoT Hub
Now provide the following parameters to create your IoT Hub:
IoT Hub Parameters
Verify the IoT Hub is successfully created:
IoT Hub created
NG the Shared Access Policies
IoT Shared Access Policies
Click Shared Access Policies,
Select “iothubowner” and enable “registry write” and copy the Shared access keys:
 Go back to your desktop and open the Device Explorer Twin,
If not already installed, install (https://github.com/Azure/azure-iot-sdkcsharp/releases/download/2017-10-23/SetupDeviceExplorer.msi ) and run the Device Explorer:
IoT Device Explorer Twin - wikiazure
Provide a name for your IoT Device
Select the Management label and Click on Create Device, provide a name for your IoT Device and then paste the Shared Access Credentials you previously copied:
Create IoT Device on Device Explorer Twin - wikiazure
You will see a notification when the device is successfully created:
Iot Device created - wikiazure
Copy connection string for the selected device
  9. In the Management label, right-click the device you just created and click “Copy connection string for the selected device”
Device Explorer copy connection - wikiazure
 Launch Arduino.
You can download it from here:
https://www.arduino.cc/download_handler.php?f=/arduino-1.8.5-windows.exe .
Add the Microsoft IoT and Arduino libraries by clicking Sketch -> Include Library à-> Manage Libraries and search for “AzureIoT”. Install the library AzureIoTHub by Arduino, the AzureIoTProtocol_MQTT by Microsoft and AzureIoTUtility by Microsoft, as shown below.
Starting with a new sketch, copy the following code:
#include <ESP8266WiFi.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiGeneric.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiSTA.h>
#include <ESP8266WiFiType.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <AzureIoTUtility.h>
#include <AzureIoTHub.h>
#include <AzureIoTProtocol_MQTT.h>
#include <DHT.h>
String ssid                         = "iot";        // your network SSID (name)
String pass                         = "microsoft" // your network password (use for WPA, or use as key for WEP)
static const char* connectionString = "HostName=daveiotdemo1.azure-devices.net;DeviceId=daveie;SharedAccessKey=1298128GASJDA12=";
#define DHTPIN 2                                   // what digital pin we're connected to
#define DHTTYPE DHT22                               // DHT11 or DHT22
IOTHUB_CLIENT_LL_HANDLE iotHubClientHandle;
IOTHUB_CLIENT_STATUS status;
WiFiClientSecure espClient;
DHT dht(DHTPIN, DHTTYPE);
void initWifi() {
    if (WiFi.status() != WL_CONNECTED)
        WiFi.stopSmartConfig();
        WiFi.enableAP(false);
        // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
        WiFi.begin(ssid.c_str(), pass.c_str());
        Serial.print("Waiting for Wifi connection.");
        while (WiFi.status() != WL_CONNECTED) {
            Serial.print(".");
            delay(500);
        Serial.println("Connected to wifi");
        initTime();
        initIoTHub();
void initTime() {
    time_t epochTime;
    configTime(0, 0, "pool.ntp.org", "time.nist.gov");
    while (true) {
        epochTime = time(NULL);
        if (epochTime == 0) {
            Serial.println("Fetching NTP epoch time failed! Waiting 2 seconds to retry.");
            delay(2000);
        } else {
            Serial.print("Fetched NTP epoch time is: ");
            Serial.println(epochTime);
            break;
static void sendMessage(const char* message)
    static unsigned int messageTrackingId;
    IOTHUB_MESSAGE_HANDLE messageHandle = IoTHubMessage_CreateFromString(message);
    if (IoTHubClient_LL_SendEventAsync(iotHubClientHandle, messageHandle, sendMessageCallback, (void*)(uintptr_t)messageTrackingId) != IOTHUB_CLIENT_OK)
        Serial.println(" ERROR: Failed to hand over the message to IoTHubClient");
    else
      (void)printf(" Message Id: %u Sent.\r\n", messageTrackingId);
    IoTHubMessage_Destroy(messageHandle);
    messageTrackingId++;
void sendMessageCallback(IOTHUB_CLIENT_CONFIRMATION_RESULT result, void* userContextCallback)
    unsigned int messageTrackingId = (unsigned int)(uintptr_t)userContextCallback;
    (void)printf(" Message Id: %u Received.\r\n", messageTrackingId);
static IOTHUBMESSAGE_DISPOSITION_RESULT IoTHubMessageCallback(IOTHUB_MESSAGE_HANDLE message, void* userContextCallback)
    IOTHUBMESSAGE_DISPOSITION_RESULT result = IOTHUBMESSAGE_ACCEPTED;
    const char* messageId = "UNKNOWN";      // in case there is not a messageId associated with the message -- not required
    messageId = IoTHubMessage_GetMessageId(message);
    const unsigned char* buffer;
    size_t size;
    if (IoTHubMessage_GetByteArray(message, &buffer, &size) != IOTHUB_MESSAGE_OK)
        Serial.println(" Error: Unable to IoTHubMessage_GetByteArray");
        result = IOTHUBMESSAGE_ABANDONED;
    else
        char* tempBuffer = (char*)malloc(size + 1);
        if (tempBuffer == NULL)
            Serial.println(" Error: failed to malloc");
        else
            (void)memcpy(tempBuffer, buffer, size);
            String messageStringFull((char*)tempBuffer);
            String messageString = "UNKNOWN";
            messageString = messageStringFull.substring(0,size);
/*            if (messageString.startsWith("OTA")) {
                  String fullURL = messageString.substring(messageString.indexOf("://") - 4);;
                  // t_httpUpdate_return OTAStatus = OTA.update(fullURL.c_str());
                  // if we do OTA, then we never return the IOTHUBMESSAGE_ACCEPTED and we have issues
            String messageProperties = "";
            MAP_HANDLE mapProperties = IoTHubMessage_Properties(message);
            if (mapProperties != NULL)
            const char*const* keys;
            const char*const* values;
            size_t propertyCount = 0;
            if (Map_GetInternals(mapProperties, &keys, &values, &propertyCount) == MAP_OK)
                if (propertyCount > 0)
                    size_t index;
                    for (index = 0; index < propertyCount; index++)
                            messageProperties += keys[index];
                            messageProperties += "=";
                            messageProperties += values[index];
                            messageProperties += ",";
            Serial.print(" Message Id: ");
            Serial.print(messageId);
            Serial.print(" Received. Message: \"");
            Serial.print(messageString);
            Serial.print("\", Properties: \"");
            Serial.print(messageProperties);
            Serial.println("\"");
        free(tempBuffer);
    return result;
void initIoTHub() {
  iotHubClientHandle = IoTHubClient_LL_CreateFromConnectionString(connectionString, MQTT_Protocol);
  if (iotHubClientHandle == NULL)
      (void)printf("ERROR: Failed on IoTHubClient_LL_Create\r\n");
  } else {
    IoTHubClient_LL_SetMessageCallback(iotHubClientHandle, IoTHubMessageCallback, NULL);
void LEDOn() {
  digitalWrite(LED_BUILTIN, LOW);
void LEDOff() {
  digitalWrite(LED_BUILTIN, HIGH);
void setup() {
  Serial.begin(115200);
  dht.begin();
  initWifi();
  pinMode(LED_BUILTIN, OUTPUT);
  LEDOff();
void loop() {
  initWifi();         // always checking the WiFi connection
  LEDOn();
  // we will process every message in the Hub
  while ((IoTHubClient_LL_GetSendStatus(iotHubClientHandle, &status) == IOTHUB_CLIENT_OK) && (status == IOTHUB_CLIENT_SEND_STATUS_BUSY))
      IoTHubClient_LL_DoWork(iotHubClientHandle);
      ThreadAPI_Sleep(1000);
  String  JSONMessage = "{\'temperature\':";
          JSONMessage += dht.readTemperature();
          JSONMessage += "}";
  sendMessage(JSONMessage.c_str());
  LEDOff();
  delay(5000);
Modify the SSID, password, and connectionString on lines 18 – 20 as shown below and click “Compile and Upload”:
Go back to the Device Explorer.
Click Message To Device. Type a message, add any desired properties and click Send, as shown below:
sensor-connected-IoT-Device-wikiazure
Tried to take a closer picture of the device in case you want to validate your sensor connectivity:
sensor IoT Device - wikiazure
Using Serial Monitor, you should be able to look the Humidity Percentage, temperature in °C and °F:
Monitoring-Temperature-IoT-Device-wikiazure
You should also be able to monitor the messages through Serial Monitor as shown below:
IoT Device Serial Monitor - wikiazure
This completes the article on how to Create an IoT Hub and connect your IoT Device.
Azure provides a robust platform for IoT with seamless integration and a diversity of hardware providers certified to enable IoT solutions in a seamless way.
Other Languages:
