This page provides a quick overview of the Technet Wiki articles related to MIIS 2003, FIM 2010 of MIM 2016 Support articles. The Wiki search engine provides you with the latest updates, but it does not provide a comprehensive overview, nor the search results are grouped (yet).
Keep in mind this this catalog page is regularly updated automatically with a powershell script. When you think the Wiki article is missing information, please add a comment or notify the initial author.
The articles are grouped based on commonly used article tags for the MIIS/FIM/MIM support content. An article is only displayed once, under it's primary tag.
These articles are FIM Help Wiki articles.
[REFERENCE] FIM Reporting Resource Wiki (Tim Macaulay, 12 apr 2013) Certificate Management Resource Wiki (Peter Geelen, 24 sep 2010) FIM 2010 Installation Companion: Accounts (Tim Macaulay, 1 feb 2012) FIM 2010 R2 Installation Companion - FIM Service (Tim Macaulay, 18 may 2012) FIM 2010 R2 SP1: How to Prepare/Execute Installation of Add-ins and Extensions via GPO (Tim Macaulay, 8 feb 2011) FIM 2010 R2 Troubleshooting: Error 3000: Access is denied. (Exception from HRESULT: 0x80070005 (Tim Macaulay, 26 jan 2013) FIM 2010 R2 Troubleshooting: SSPR Error 3000 and 3004 – not authorized to register for password reset (Tim Macaulay, 14 jan 2013) FIM 2010 R2 Troubleshooting: SSPR Error 3000: PWReset Activity's MIIS Password Set call failed with call-failure:0x80004005 (Tim Macaulay, 16 jun 2013) FIM 2010 Troubleshooting: Enabling Verbose Logging for the Lotus Notes Management Agent (Walt Whitman [MSFT], 6 nov 2012) FIM 2010 Troubleshooting: EventID 6313 - Unable to Load Performance Counters for Management Agent (Walt Whitman [MSFT], 25 mrt 2013) FIM 2010 Troubleshooting: FIMMA- Failed to connect to the specified database (Tim Macaulay, 20 apr 2013) FIM 2010: How to Allow Group Administrators to Add/Remove Members to a Group they do not own (Tim Macaulay, 11 may 2012) FIM 2010: Quick Guide to installing BHOLD Core (Tim Macaulay, 4 jul 2013) FIM CM Reference: Increasing the Max Pool Size in FIM CM (Steve Light - MSFT, 21 jun 2013) FIM CM Reference: Improve Search Performance When Using Custom or AD Attributes (Steve Light - MSFT, 21 jun 2013) FIM Password Synchronization (PCNS) Resource Wiki (Tim Macaulay, 8 apr 2011) FIM Reference: Checking / Configuring Attribute Precedence (Tim Macaulay, 18 oct 2011) FIM Reference: Discovery Errors (Tim Macaulay, 19 jun 2013) FIM Reference: Extensible Connectivity Management Agent (ECMA) 2.0 Resource Wiki (Tim Macaulay, 1 apr 2013) FIM Reference: How to clear the run history (Tim Macaulay, 26 jan 2012) FIM reference: How to Easily Export a Connector Space List to Excel (Tim Macaulay, 16 jun 2013) FIM REFERENCE: How to Enable/Disable an AD account and set other UAC flags in a Declarative Sync Rule (Andrew Masse, 23 dec 2013) FIM Reference: How to Flow msExchHideFromAddressList but Filter if the Value Is True (Tim Macaulay, 4 jun 2013) FIM Reference: How to register the FIM WMI Provider (Tim Macaulay, 28 aug 2012) FIM Reference: Monitoring FIM 2010 and/or FIM 2010 R2 (Tim Macaulay, 13 jul 2012) FIM Reference: Portal, Password Registration Portal, and Password Reset Portal Software Requirements (Tim Macaulay, 20 jan 2013) FIM Reference: Refreshing Interfaces of ECMA 2.0 Version of Lotus Domino MA (Walt Whitman [MSFT], 13 aug 2013) FIM Reference: Which Run Profile Do I Run First? (Tim Macaulay, 8 dec 2012) FIM Reporting Troubleshooting: Performance Issue with p_DiscoveryDataPurgingByBaseManagedEntity (Tim Macaulay, 13 apr 2013) FIM Self-Service Password Reset (SSPR) Resources (Tim Macaulay, 20 apr 2012) FIM Service Troubleshooting: Set creation fails when using negative conditions (Tim Macaulay, 21 feb 2013) FIM SSPR Troubleshooting: Error 3000 - Value cannot be null (Tim Macaulay, 28 jan 2013) FIM Troubleshooting: ADMA Full Import: no-start-bad-ma-config Error 6009 (Tim Macaulay, 12 may 2013) FIM Troubleshooting: ADMA Home Folder Attribute is not flowing correctly (Tim Macaulay, 26 jan 2013) FIM Troubleshooting: Attempted to perform an unauthorized operation. (Tim Macaulay, 5 nov 2012) FIM Troubleshooting: BHOLD Self-Service module fails to load due to Unauthorized Login (Tim Macaulay, 14 may 2013) FIM Troubleshooting: CM Upgrade Fails exception executing SQL statement (Steve Light - MSFT, 21 may 2013) FIM Troubleshooting: Connecting to remote server failed with the following error message: Access is denied (Tim Macaulay, 16 nov 2012) FIM Troubleshooting: ECMA 2.x error extensible-connector-refresh-required (Tim Macaulay, 16 apr 2013) FIM Troubleshooting: Error 25009.The Forefront Identity Manager Synchronization Service setup wizard cannot configure the specified database (Tim Macaulay, 3 dec 2012) FIM Troubleshooting: Event ID 10016 - The application-specific permission settings do not grant Local Activation permission for the COM Server application (Tim Macaulay, 16 jun 2013) FIM Troubleshooting: Failed to retrieve schema and Event ID 6331 (Tim Macaulay, 16 jul 2013) FIM troubleshooting: Failed-Creation-Via-Web-Services: InvalidRepresentationException: ValueViolatesUniqueness (Tim Macaulay, 11 may 2013) FIM Troubleshooting: Failed-Creation-Via-Web-Services: The endpoint could not dispatch the request (Tim Macaulay, 11 may 2013) FIM Troubleshooting: Failure to install hotfix – VerifySharePoint2010ClaimsAuthenticationOff. Return value 3 (Tim Macaulay, 30 apr 2013) FIM Troubleshooting: FIM MA - Failed to Retrieve Schema Troubleshooter (Tim Macaulay, 4 may 2012) FIM Troubleshooting: FIM Service Polling the Exchange Web Service (EWS) fills the Application Event Log (Tim Macaulay, 22 may 2013) FIM Troubleshooting: FIM Service Start-up Timeout (Steve Light - MSFT, 10 oct 2012) FIM Troubleshooting: FIM Services do not start during upgrade and/or new installation (Tim Macaulay, 1 sep 2012) FIM Troubleshooting: FIMMA Export is Slow (Tim Macaulay, 21 mrt 2013) FIM Troubleshooting: How to enable tracing in the Directory Synchronization Password Synchronization component (Tim Macaulay, 16 jul 2013) FIM Troubleshooting: Install FIM Data Warehouse Support Scripts on a Remote SQL Server (Tim Macaulay, 16 jun 2013) FIM Troubleshooting: ma-extension-error when exporting to Exchange 2007 or 2010 (Tim Macaulay, 2 nov 2011) FIM Troubleshooting: PCNS received an RPC exception attempting to deliver (Tim Macaulay, 14 apr 2013) FIM Troubleshooting: Portal access - URL authorization failed for the request (Tim Macaulay, 12 may 2013) FIM Troubleshooting: SSPR Registration Error 3008 - An error occurred while receiving the HTTP response (Andrew Masse, 28 may 2014) FIM Troubleshooting: stopped-dll-exception troubleshooter document (Tim Macaulay, 29 mrt 2012) FIM Troubleshooting: stopped-dll-exception: WinRM cannot process the request: Access Denied (Tim Macaulay, 23 dec 2012) FIM Troubleshooting: SUN One MA Import Stopped-Connectivity (Tim Macaulay, 14 apr 2013) FIM Troubleshooting: Synchronization Console Hangs When Modifying a Lotus Notes Management Agent (Walt Whitman [MSFT], 17 may 2013) FIM Troubleshooting: WMI Provider Load Failure (Tim Macaulay, 12 nov 2012) FIM/ILM Troubleshooting: Not able to create enabled Active Directory accounts because Kerberos Issues (Tim Macaulay, 12 mrt 2012) FIM: How to reindex all of the tables in the backend FIMSynchronizationService Database (Tim Macaulay, 10 jan 2012) FIM: Troubleshooting : An exception occurred while running SolutionPackUtility.exe (Tim Macaulay, 15 jul 2013) FIM2010 GALSync: How to Flow msExchHideFromAddressList Except When the Value is True (Tim Macaulay, 2 may 2013) FIM2010 Reference: What Version of SQL Server to Use on the FIM Backend (Tim Macaulay, 17 aug 2011) FIM2010 Troubleshooting: Run Profiles 0x8004100E - Invalid Namespace (Tim Macaulay, 20 jan 2013) FIM2010: How to Use OOB Function Evaluator workflow to parse EMail for MailNickname (Tim Macaulay, 15 apr 2013) FIMSync Troubleshooting: Stopping Every Ten Minutes - Oracle MA (Tim Macaulay, 14 apr 2013) FIM-TROUBLESHOOTING: ORACLE MA: Full Import Error “Completed No Objects†(Tim Macaulay, 7 nov 2012) FIM-TROUBLESHOOTING-PCNS: Event ID 6025 – Status: 1747 (Tim Macaulay, 18 jan 2013) GALSync: How to Customize TargetAddress on Export Attribute Flow (Tim Macaulay, 23 aug 2011) How to check the object deletion rule in FIM 2010 Synchronization server (Tim Macaulay, 20 mrt 2013) How to install FIM using a SQL Server Alias (Tim Macaulay, 30 nov 2012) How to set Manager Attribute from Text-File MA in FIM2010 (Tim Macaulay, 1 jul 2013) How to use PowerShell to delete an orphaned Synchronization Rule in FIM (Tim Macaulay, 22 oct 2012) How to use Powershell to Export the FIM Sync Run History to a CSV File (Tim Macaulay, 16 jan 2013) Identity Manager: Run Profiles Resource Wiki (Tim Macaulay, 20 jul 2012) Troubleshooting BHOLD Core installation: Contact your support personnel or package vendor. Custom action CA_CoreProductGetWebsiteExists script error -2147217394, (Tim Macaulay, 30 jul 2013) Troubleshooting FIM 2010 R2: SSPR Error 3000:could not load file or assembly: 0x80131047 (Tim Macaulay, 18 jan 2013) Troubleshooting FIM CM: Certificate Request Error: Denied by Policy Module (Steve Light - MSFT, 4 jun 2013) Troubleshooting FIM CM: error 0x80092013 - revocation function was unable to check revocation (Tim Macaulay, 26 jan 2013) Troubleshooting FIM CM: Viewing the Policy Module Properties with the Active Directory Certificate Services Console Fails (Steve Light - MSFT, 11 jun 2013) Troubleshooting FIM CM: While Trying to Search for Cards to Print with the Bulk Client You May Get a HTTP 404 Error (Walt Whitman [MSFT], 5 oct 2012) Troubleshooting FIM CM:Attempts to Retire Smart Card Receive Error 0x80072116 (Steve Light - MSFT, 11 jun 2013) Troubleshooting FIM GALSync: No contacts to provision (Tim Macaulay, 14 feb 2013) Troubleshooting FIM Performance: Slow or Hanging Full Synchronization (Tim Macaulay, 30 nov 2012) Troubleshooting FIM Reporting: A Transport-Level Error Has Occurred During Initial Sync (Tim Macaulay, 3 jun 2013) Troubleshooting FIM Reporting: Installing with warning: “You have entered an invalid System Center Service Management Name†(Tim Macaulay, 15 apr 2013) Troubleshooting FIM Service and Portal Installation - The Web site address '/IdentityManagement' already in use. (Tim Macaulay, 21 mrt 2013) Troubleshooting FIM Service installation Error 1722: CheckSharepointFarmAdministratorWithOpenPermission returned actual error code (Tim Macaulay, 6 aug 2013) Troubleshooting FIM Service: Upgrade Fails on 'GetCertThumbprintFromName' (Tim Macaulay, 4 jun 2013) Troubleshooting FIM SSPR: Could not connect to the password reset service. (Tim Macaulay, 14 apr 2013) Troubleshooting FIM Sync: stopped-dll-exception: The following error occurred while using Kerberos authentication (Tim Macaulay, 18 jul 2012) Troubleshooting FIM Synchronization: unexpected-error thrown for a single object (Tim Macaulay, 20 mrt 2013) Troubleshooting FIM: Failed to connect to specified database. The extension operation aborted due to an internal error in FIM Synchronization Service (Tim Macaulay, 20 may 2013) Troubleshooting FIM: An update conflict has occurred, and you must re-try this (Tim Macaulay, 15 jul 2013) Troubleshooting FIM: BHOLD Increase session lifetime for BHOLD core (Tim Macaulay, 4 jun 2013) Troubleshooting FIM: BHOLD SP1 - Users are getting added to other user's personal roles (Tim Macaulay, 3 jun 2013) Troubleshooting FIM: Cannot generate SSPI Context (Tim Macaulay, 16 jul 2013) Troubleshooting FIM: Could not load file or assembly (Tim Macaulay, 30 nov 2012) Troubleshooting FIM: ECMA V2 – Export Only Management Agent – The image or delta doesn’t have an anchor (Tim Macaulay, 7 may 2013) Troubleshooting FIM: Error Code 9506 on ADMA When Trying to Connect to Domain (Tim Macaulay, 23 apr 2013) Troubleshooting FIM: Event ID 6152 – stopped-extension-dll-load (Tim Macaulay, 29 may 2013) Troubleshooting FIM: Event ID 6309 - Connection is busy with results for another command (Tim Macaulay, 24 apr 2013) Troubleshooting FIM: Event ID 6401 – management agent controller encountered an unexpected error (Tim Macaulay, 26 jan 2013) Troubleshooting FIM: extension-unexpected-attribute-value: mv-deletion: msExchDynamicDistributionL (Tim Macaulay, 9 aug 2013) Troubleshooting FIM: HTTP client has prematurely closed the underlying TCP connection (Tim Macaulay, 22 jan 2013) Troubleshooting FIM: Installation Hot Fix Update Rolls Back Without Warning or Error / (SolutionPackUtility) (Tim Macaulay, 9 aug 2011) Troubleshooting FIM: Not able to create an Oracle Management Agent when using the Oracle 11g client (Tim Macaulay, 14 apr 2013) Troubleshooting FIM: Notification Workflows that send email from the FIM Service Account are not working (Tim Macaulay, 19 feb 2013) Troubleshooting FIM: Problem Firing Powershell Script to Lync Enable Users From Within a FIM Workflow (Walt Whitman [MSFT], 13 dec 2012) Troubleshooting FIM: Receiving Event ID 1000 with Faulting Application mmsscrpt.exe (Tim Macaulay, 3 apr 2013) Troubleshooting FIM: Refresh Schema on FIM MA fails with Event ID 6331 (Tim Macaulay, 3 jun 2013) Troubleshooting FIM: Report Updates not Available after Hotfix Upgrade. (Tim Macaulay, 4 jul 2013) Troubleshooting FIM: Server Database could not be successfully deployed. (Tim Macaulay, 28 jul 2013) Troubleshooting FIM: Service Is Not Available - Invalid SPN on the Application Pool Identity Account (Tim Macaulay, 14 feb 2013) Troubleshooting FIM: SSPR Error 3000 - IIS Authentication Settings (Tim Macaulay, 18 jan 2013) Troubleshooting FIM: SSPR Error 3003 - The current user account is not recognized by Forefront Identity Manager. Please contact your help desk or system administrator. (-Jeff Ingalls-, 9 oct 2013) Troubleshooting FIM: SSPR-Error 3000-pwUnrecoverable (Tim Macaulay, 6 mrt 2013) Troubleshooting FIM: sync-rule-invalid-xml-attribute-flow (Tim Macaulay, 21 feb 2013) Troubleshooting FIM: The property value you specified, '-1073740026', isn't defined in the Enum type 'Nullable`1' (Tim Macaulay, 16 jun 2013) Troubleshooting FIM2010R2 SSPR Error 3000 – The given assembly name or codebase was invalid (Tim Macaulay, 27 jan 2013) Troubleshooting GALSync: contacts are not being created for new users (Tim Macaulay, 16 jan 2013) Troubleshooting GALSYNC: Exchange 2010 Provisioning Updating 'mail' Attribute error exported-change-not-reimported (Tim Macaulay, 20 mrt 2013) Troubleshooting GALSync: Mixed environment - Exchange 2007 contacts not showing in addressbook (Tim Macaulay, 19 apr 2013) Troubleshooting GALSync: mv-constraint-violation (msExchSafeSenderHash) (Tim Macaulay, 10 may 2012)
These article are created by Tim Macauly.
FIM 2010 – How to validate FIM Service Management Agent Account (Tim Macaulay, 7 feb 2012) FIM 2010 R2 Installation Companion - Synchronization Service Install (Tim Macaulay, 17 may 2012) FIM 2010 R2 Installation Companion for FIM Portal, Password Reset Portal, Registration Portal (Tim Macaulay, 19 may 2012) FIM 2010 Troubleshooting: Discovery Errors - multi-single-mismatch (Tim Macaulay, 21 mrt 2013) FIM 2010: Sharing GALs and Free/Busy Info between Exchange Orgs (Tim Macaulay, 8 feb 2012) FIM Installation Companion - Service Principle Names (SPNs) (Tim Macaulay, 12 may 2012) FIM Reference: How to automate run profiles via the script button (Tim Macaulay, 20 jul 2012) FIM Reference: How to set more granular permissions than 'replicating directory changes' on a source AD read by the ADMA (Tim Macaulay, 13 apr 2013) FIM Reference: Logging for Certificate Management (Tim Macaulay, 20 apr 2013) FIM Reference: Migrating from MIIS or ILM to FIM 2010 (Tim Macaulay, 17 aug 2011) FIM SSPR TROUBLESHOOTING: The FIM Password and Authentication Extensions are not currently installed on this computer (Tim Macaulay, 1 aug 2012) FIM Troubleshooting: AD LDS Provisioning: unexpected-error with No Such Attribute (Tim Macaulay, 6 jun 2012) FIM TROUBLESHOOTING: ADLDS MA - DN is not valid (Tim Macaulay, 2 may 2012) FIM Troubleshooting: Extension-DLL-Exception (Tim Macaulay, 14 feb 2012) FIM Troubleshooting: GALSync/ADMA Export Issues (Tim Macaulay, 2 may 2012) FIM Troubleshooting: ma-extension-error Event ID 6500 - name is not valid for Alias (Tim Macaulay, 3 jun 2012) FIM Troubleshooting: Provisioning users to AD returns Kerberos-no-logon-server (Tim Macaulay, 14 apr 2013) FIM Troubleshooting: SSPR Rich client - 'an error was encountered' (Tim Macaulay, 14 apr 2013) FIM/MIM Troubleshooting: stopped-dll-exception - The WinRM client received an HTTP status code of 403 from the remote WS-Management service (Tim Macaulay, 24 may 2012) FIM: How to Display the Security Groups (SGs) Navigation Bar Menu Item to Non-FIM Administrators (Tim Macaulay, 29 apr 2012) FIM2010 TROUBLESHOOTING: Error 25070 - Error connecting to database FIMSynchronizationService. Invalid class string (Tim Macaulay, 13 jul 2012) FIM2010 Troubleshooting: FIM Service Is Not Available (Tim Macaulay, 27 apr 2012) FIM2010: How to enable logging for the webservices connector (Tim Macaulay, 17 jul 2012) FIMMA-EXPORT: PermissionDeniedException (Tim Macaulay, 7 feb 2012) Global Address List Synchronization (GALSync) Resources (Tim Macaulay, 4 nov 2010) How to Enable FIM Service Management Agent Tracing (Tim Macaulay, 28 apr 2012) How to Enable FIM Service Tracing (Tim Macaulay, 28 apr 2012) How to Enable Verbose Tracing for the FIM Portal (Tim Macaulay, 28 apr 2012) PCNS: Troubleshooting Event ID 6025 (Tim Macaulay, 9 aug 2011) Troubleshooting FIM 2010: WebServices MA - Failed to Update Discovery (Tim Macaulay, 18 jul 2012) Troubleshooting FIM CM: 'Logon failure: unknown user name or bad password' (Tim Macaulay, 16 may 2012) Troubleshooting FIM Installation: Converting Representation of References (Tim Macaulay, 17 jul 2012) Troubleshooting FIM SSPR Registration: You or somebody else attempted to reset your password. (Tim Macaulay, 12 may 2013) Troubleshooting FIM Sync: Event ID: 6801 - 'The Exchange server address list service failed to respond' (Tim Macaulay, 4 may 2012) Troubleshooting FIM Sync: extension-dll-exception ObjectAlreadyExistsException (Tim Macaulay, 7 jun 2012) Troubleshooting FIM Sync: MissingParentObjectException (Tim Macaulay, 14 feb 2012) Troubleshooting FIM: Error 25009: CONDITIONAL Failed - SET Options Incorrect 'ARITHABORT' (Tim Macaulay, 25 jul 2012) Troubleshooting FIM: Event ID: 1000: Faulting application name: miiserver.exe, version: 4.0.2592.0, time stamp: 0x4b6790ea (Tim Macaulay, 26 jul 2012) Troubleshooting FIM: FIM Portal, SharePoint and Logon Name displaying on FIM Portal Site (Tim Macaulay, 28 apr 2012) Troubleshooting FIM: FIM Synchronization Service loses connection with backend database (Tim Macaulay, 18 oct 2012) Troubleshooting FIM: Group Administrator gets Access Denied when attempting to Add/Remove a member from a group they do not own (Tim Macaulay, 11 may 2012) Troubleshooting FIM: Mapping Type and Flow Direction Radio Buttons Are Not Visible (Tim Macaulay, 1 jun 2012) Troubleshooting FIM: Reporting Installation Using SCCM 2012 SP1 (Tim Macaulay, 3 jun 2013) Troubleshooting FIM: Synchronization error: unexpected-error on a single object (Tim Macaulay, 20 mrt 2013) Troubleshooting FIMCM: No mapping between account names and security IDs was done (Tim Macaulay, 15 jul 2012) Troubleshooting FIMCM: RPC server is unavailable - Error 0x800706BA (Tim Macaulay, 21 may 2012) TROUBLESHOOTING: 0x800700b7 Cannot create a file when that file already exists (Tim Macaulay, 30 may 2012) TROUBLESHOOTING: CCertRequest::GetCAPropertyFlags: The version of the OLE on the client and server machines does not match. 0x80010110 (Tim Macaulay, 26 jul 2012) TROUBLESHOOTING: Failed to retrieve schema or cannot connect to database while creating a FIM MA (Tim Macaulay, 5 apr 2012)
FIM 2010 Troubleshooting: Error 25070 These workstations have sessions with open files on this server (Tim Macaulay, 1 feb 2012) FIM 2010: Working with the Recycle Bin Feature in Windows Server 2008 R2 AD (Tim Macaulay, 3 feb 2012) FIM Reference: FIM 2010 R2 SP1 Information (Tim Macaulay, 3 feb 2013) FIM Reference: FIM Resource Wiki Page Index (Tim Macaulay, 1 jun 2012) FIM Reference: How to Check for Pending Exports (Tim Macaulay, 1 sep 2012) FIM Reference: How to determine the build of FIM 2010 (Tim Macaulay, 20 apr 2012) FIM Reference: WebServices Connector (Tim Macaulay, 13 jul 2012) FIM Synchronisation Troubleshooting: Novell eDirectory MA - Server Down (Tim Macaulay, 26 jan 2012) FIM Troublesooting: Event ID: 6311/6401 stopped-server, obsoletionlist.cpp(319): 0 is not a valid DN depth (Tim Macaulay, 15 may 2012) FIM: How to Acquire the Microsoft Exchange Server 2010 Client Access Server (CAS Server) Information for Microsoft Exchange Server 2010 Provisioning (Tim Macaulay, 15 jun 2011) FIM: How to export using a threshold (Tim Macaulay, 13 apr 2012) FIM: How to test the exporting of data before it is exported (Tim Macaulay, 13 apr 2012) FIM2010 Troubleshooting: Event ID 6208 - The server encryption keys could not be accessed (Tim Macaulay, 9 oct 2012) GalSync Creates Contacts that are not Seen in the GAL (Tim Macaulay, 16 aug 2011) GALSync Troubleshooting: Permission-Issue - Insufficient access rights to perform the operation (Tim Macaulay, 20 feb 2012) How to Create a Usage Keyword in FIM Portal (Tim Macaulay, 29 apr 2012) How to refresh the schema of the FIM Service Management Agent (Tim Macaulay, 12 sep 2011) How to use a FIM run profile to export to a drop file (Tim Macaulay, 13 apr 2012) How to Work with More Than One Partition in a Management Agent (Tim Macaulay, 24 feb 2012) MIISERVER.EXE Process Spikes in Memory Usage When Exporting to Exchange 2010 (Tim Macaulay, 22 jun 2011) Troubleshooting FIM 2010 R2: Service Not Available When Accessing FIM Portal (Tim Macaulay, 21 mrt 2013) Troubleshooting FIM2010 SSPR: Error 3000 - Access Denied (Tim Macaulay, 21 mrt 2013)
Create a Mail-Enabled User Object for Exchange 2007/2010 (Tim Macaulay, 9 nov 2011) FIM 2010 Hotfix installation - Documentation of the MSP files (Tim Macaulay, 12 sep 2011) FIM 2010 Troubleshooting: Error 1920 - FIMPasswordReset failed to start (Tim Macaulay, 29 jun 2011) FIM 2010: How to delete Management Agent and Connector Space (Tim Macaulay, 12 aug 2011) FIM 2010: How to migrate FIM backend database to new SQL Server (Tim Macaulay, 18 jul 2011) FIM 2010: How to Validate Information Being Exported (Tim Macaulay, 15 dec 2011) FIM CM Troubleshooting: Object reference not set to an instance of an object (Tim Macaulay, 29 aug 2011) FIM Reference: Configuring Exchange 2007 Provisioning (Tim Macaulay, 2 nov 2011) FIM Reference: Configuring Exchange 2010 Provisioning (Tim Macaulay, 2 nov 2011) FIM Service Management Agent: Deleting the Connector Space (Tim Macaulay, 12 aug 2011) FIM Synchronization Rules: Dropdowns Contain No Data or Missing Data (Tim Macaulay, 1 aug 2011) FIM Synchronization Service Crashing on Full Import (Stage Only) (Tim Macaulay, 12 aug 2011) FIM Troubleshooting: Accessing the FIM Portal using a Sensitive Account (cannot be delegated) (Tim Macaulay, 2 mrt 2012) FIM/MIM Troubleshooting: ExternalEmailAddress Is Mandatory on MailUser. Property Name: ExternalEmailAddress (Tim Macaulay, 2 aug 2011) FIM: How to Script for Clearing Run History (Tim Macaulay, 17 oct 2011) FIM2010 Troubleshooting: Service Not Available - The Portal cannot connect to the middle tier using the web service interface (Tim Macaulay, 1 aug 2011) FIM2010/MIM2016 Troubleshooting : 'HTTP Error 401. The requested resource requires user authentication' (Tim Macaulay, 29 aug 2011) FIM2010/MIM2016: How to Capture a Verbose Log for CM or CLM (Tim Macaulay, 28 jul 2011) Full Import (Stage Only) Causes FIM Synchronization Service (miiserver.exe) to Crash (Tim Macaulay, 12 aug 2011) GALSync Troubleshooting: LegacyExchangeDN is not populated (Tim Macaulay, 26 feb 2012) MIM Synchronization Troubleshooting: Event ID 6301: export-flow failed 0x80230304 (Tim Macaulay, 7 oct 2011) O365/DirSyncTroubleshooting: SQL Backend is full (Tim Macaulay, 26 jan 2012) PCNS Logging (Tim Macaulay, 13 jul 2011) Permissions for GALSync User MA User Account (Tim Macaulay, 3 oct 2011) Troubleshooting FIM SSPR: Password Reset Registration - 'An error was encountered. Please call helpdesk or your system.' (Tim Macaulay, 5 aug 2011)
