Bronze Award Winner Award in March 2019
Many times customer requirement to send table output in specific folder.This data used for presentation or send other vendor.This is possible by SSIS and BCP.
BCP help
Example of BCP:
BCP.exe tst.dbo.testrel out tst.bcp -c -t -T -S .
Main code
USE [msdb]
GO
/****** Object:  Job [bcp1]    Script Date: 2/26/2016 12:59:54 PM ******/
BEGIN TRANSACTION
DECLARE @ReturnCode INT
SELECT @ReturnCode = 0
IF NOT EXISTS (SELECT name FROM msdb.dbo.syscategories WHERE name=N'[Uncategorized (Local)]' AND category_class=1)
BEGIN
EXEC @ReturnCode = msdb.dbo.sp_add_category @class=N'JOB', @type=N'LOCAL', @name=N'[Uncategorized (Local)]'
IF (@@ERROR <> 0 OR @ReturnCode <> 0) GOTO QuitWithRollback
END
DECLARE @jobId BINARY(16)
EXEC @ReturnCode =  msdb.dbo.sp_add_job @job_name=N'test',
        @enabled=1,
        @notify_level_eventlog=0,
        @notify_level_email=0,
        @notify_level_netsend=0,
        @notify_level_page=0,
        @delete_level=0,
        @description=N'No description available.',
        @category_name=N'[Uncategorized (Local)]',
        @owner_login_name=N'dbaadmin', @job_id = @jobId OUTPUT
/****** Object:  Step [step1]    Script Date: 2/26/2016 12:59:55 PM ******/
EXEC @ReturnCode = msdb.dbo.sp_add_jobstep @job_id=@jobId, @step_name=N'step1',
        @step_id=1,
        @cmdexec_success_code=0,
        @on_success_action=1,
        @on_success_step_id=0,
        @on_fail_action=2,
        @on_fail_step_id=0,
        @retry_attempts=0,
        @retry_interval=0,
        @os_run_priority=0, @subsystem=N'TSQL',
        @command=N'DECLARE @filename NVARCHAR(4000) =''C:\tmp\excelexport''+Convert(varchar(8),getdate(),112)+''.csv''
DECLARE @cmd1 NVARCHAR(4000)
set @cmd1 = ''BCP [ADB].[dbo].[monitoring]  OUT  ''+ @filename + '' -c -T -t, -S''+ @@servername
exec master..xp_cmdshell @cmd1
        @database_name=N'master',
        @flags=0
EXEC @ReturnCode = msdb.dbo.sp_update_job @job_id = @jobId, @start_step_id = 1
EXEC @ReturnCode = msdb.dbo.sp_add_jobserver @job_id = @jobId, @server_name = N'(local)'
COMMIT TRANSACTION
GOTO EndSave
QuitWithRollback:
    IF (@@TRANCOUNT > 0) ROLLBACK TRANSACTION
EndSave:
GO
References
Forum: Automation
