Windows 7 and Windows Server 2008 R2 include a new WMI class, Win32_OptionalFeature, that allows you to view the status of optional features in Windows (to query server role status, use Win32_ServerFeature).
The DISM command-line tool lets you view the same information about optional features using the command:
dism /online /get-features
You can also use DISM to check on the status of one specific optional feature. For example, to look at the status of NetFx2-Servercore:
C:\>dism /online /get-featureinfo:NetFx2-ServerCore
Deployment Image Servicing and Management tool Version: 6.1.7600.16385
Image Version: 6.1.7600.16385
Feature Information:
Feature Name : NetFx2-ServerCore Display Name : Microsoft .NET Framework 2.0 ServerCore Description : Microsoft .NET Framework 2.0 ServerCore Restart Required : Possible State : Disabled
Custom Properties:
(No custom properties found)
The operation completed successfully.
See Querying the Status of Optional Features on MSDN for equivalent PowerShell commands.
The following Vbscript code was generated using Scriptomatic Version 2.0. It will output the optional features and their status.
On Error Resume Next Const wbemFlagReturnImmediately = &h10 Const wbemFlagForwardOnly = &h20 strComputer = "." Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\CIMV2") Set colItems = objWMIService.ExecQuery("SELECT * FROM Win32_OptionalFeature", "WQL", _ wbemFlagReturnImmediately + wbemFlagForwardOnly) For Each objItem In colItems WScript.Echo "Caption: " & objItem.Caption WScript.Echo "Description: " & objItem.Description WScript.Echo "InstallDate: " & WMIDateStringToDate(objItem.InstallDate) WScript.Echo "InstallState: " & objItem.InstallState WScript.Echo "Name: " & objItem.Name WScript.Echo "Status: " & objItem.Status WScript.Echo Next Function WMIDateStringToDate(dtmDate) WScript.Echo dtm: WMIDateStringToDate = CDate(Mid(dtmDate, 5, 2) & "/" & _ Mid(dtmDate, 7, 2) & "/" & Left(dtmDate, 4) _ & " " & Mid (dtmDate, 9, 2) & ":" & Mid(dtmDate, 11, 2) & ":" & Mid(dtmDate,13, 2)) End Function
On a Server Core install of Windows Server 2008 R2, the Dfsradmin.exe command-line tool is installed as part of the DFSR-Infrastructure-ServerEdition optional feature. However if you attempt to run Dfsradmin and you have not also installed the .NET Framework 2.0 ServerCore feature you will receive the following error:
Application Error The application was unable to start correctly (0xc0000135). Click OK to close the application.
Therefore if you want to script Dfsradmin commands, it can be helpful to first check to make sure the NetFx2-ServerCore feature is installed.
You can confirm an optional feature such as NetFx2-ServerCore is installed with a script such as this:
On Error Resume Next Const wbemFlagReturnImmediately = &h10 Const wbemFlagForwardOnly = &h20 strComputer = "." Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\CIMV2") Set colItems = objWMIService.ExecQuery("SELECT * FROM Win32_OptionalFeature", "WQL", _ wbemFlagReturnImmediately + wbemFlagForwardOnly) For Each objFeature In colItems If objFeature.Name = "NetFx2-ServerCore" And objFeature.InstallState = "1" Then blnNetFx2ServerCore = True End If Next If blnNetFx2ServerCore Then Wscript.Echo "NetFx2-ServerCore is installed." Else Wscript.Echo "NetFx2-ServerCore is not installed." End If
