Sometimes you try to open "Microsoft Management Console (MMC)" and you receive "An attempt was made to reference a token that does not exist" error. This error may be caused by corrupt files
Here is your Solution:
Open a Command Prompt (CMD) in ELEVATED MODE (run as administrator) and navigate to %WINDIR%\System32 and re-register the required DLL files using the following command:
For /F %s in ('dir /b *.dll') do regsvr32 /s %s
