Table of Contents
Issue
Sometimes you try to open "Microsoft Management Console (MMC)" and you receive the error
"An attempt was made to reference a token that does not exist".
Root cause
This error may be caused by corrupt files
Solution:
Open a Command Prompt (CMD) in ELEVATED MODE (run as administrator) and navigate to %WINDIR%\System32 and re-register the required DLL files using the following command:
For /F %s in ('dir /b *.dll') do regsvr32 /s %s
