Shapes in the VMPD are divided into the following categories:
  • The Management Pack shape. This is the basic shape that appears in all management pack diagrams. It provides properties specific to the management pack. This shape is not found on any of the tabs in the Shapes pane, but is always found on the drawing surface.
  • Modeling shapes. These shapes are used to draw a picture of the structure of your application. This category includes the shapes found on the MP Modeling and MP Modeling Computer Group tabs. You can automatically connect modeling shapes by dropping them on top of each other.
  • Roll-up shapes. These are used to connect modeling shapes, and to aggregate the health status of groups of modeling shapes. They also define how health should roll up between modeling shapes in your application.
  • Monitoring shapes. These are connected to modeling shapes. They define what kind of monitoring should be done (like monitoring a Windows service, or monitoring a Windows performance counter).
  • Single Server Patterns. These are “quick start” scenarios based on commonly used application patterns. These have pre-defined components and monitoring (you will still need to define some configuration). After dropping these on the drawing surface, you can add and remove shapes as required.
  • Distributed patterns. These are another set of scenarios based on commonly used distributed application patterns. Like the single-server pattern shapes, these provide a starting point for your drawing, and can be modified as necessary.
The modeling and monitoring shapes are covered in this article. The patterns are discussed in Pattern Reference for Visio Management Pack Designer.
These shapes are located in separate tabs of the Shapes pane. However, if you select the Quick Shapes tab, all the shapes are available in one place. If you're not certain how to use a shape, hovering over the shape opens a Tooltip with some information about the shape.
The Management Pack Shape
This shape always appears on any drawing and represents the overall Management Pack. It has the following properties:
Property Description
Management Pack Name The name of your Management Pack
Id The id of your Management Pack. This is the Management Pack file name. By default this name is the same as the Management Pack with spaces removed from the name.
Description A description of your Management Pack. Users will see this description when they import the Management Pack into the SCOM environment.
Version The version of your Management Pack
Windows Version If you are writing a Windows Management Pack (if using the Windows Server Role or Windows Role Service) and it is compatible only with a specific Windows version, you can specify the version here. This property supports the following settings:
All: The Management Pack works on all Windows versions
Range: The Management Pack works on a specific range of Windows Versions
Specific Version: The Management Pack only works on a specific Windows version
Specific Version and Above: The Management Pack works on a specific Windows version and any version greater than this.
Connector Mode If this is set to TRUE, the tool will generate a connector management pack that customers can optionally import.
Modeling Shapes
Modeling shapes are used to describe the structure of your monitored application, and how the components of the application relate to each other. This section describes the different modeling shapes and their properties. Note that some shapes cannot be used standalone; they must be attached to other shapes. You can also include several standalone shapes in the same drawing. For example, you can put a Server Role and Server Computer Group in the same drawing; they do not need to be attached to each other.
Server Role shape
This shape represents a server role, such as a SQL Server Database Server Role. It could also represent a Windows Server Role, such as DNS Server or WINS server. This shape can be used standalone, or it could be attached to the roll-up container or Windows Application shape. The shape has the following properties:
Name The name of the Server Role
How to Find The method Operations Manager can use to find this server role. This property can have one of the following four values: HKLM Registry Key, HKLM Registry Value, Windows Server Role, or WMI Query.
Affect Computer Health Determines whether the Server Role should affect the health of the monitored computer as shown in the Operations Manager Console.
Server Component shape
This shape represents a component, such as a SQL Server Database. This shape can be used standalone or attached to a Server Role, another Server Component, roll-up container or Windows Application shape. The shape has the following properties:
Name The name of the Server Component
How to Find The method Operations Manager can use to find this component. This property can have one of the following four values: HKLM Registry Key, HKLM Registry Value, Windows Server Role, or WMI Query.
Affect Computer Health Determines whether the Server Role should affect health of the monitored computer as shown in the Operations Manager Console.
Roll-up Container
This shape is used to roll up health from Server Role, Server Component, or Server Computer Group shapes. This shape cannot be used standalone. A typical use of this shape would be to represent an Active Directory Site. The roll-up container can be attached to the Windows Application shape, but not to any other shape. The shape has the following properties:
Name The name of the Roll-up Container
Use Registry Value for Container Name You can use this shape to dynamically discover instances of the server role or component being rolled up, based on a registry value. For each unique value found in a registry key, a unique instance will be created. If this setting is set to TRUE, you must enter the HKLM registry value to use for the container name.
Windows Application
This shape is used to roll up health from Roll-up Container, Server Role, Server Component or Server Computer Group. This shape cannot be used standalone. A typical use of this shape would be to represent an installation of your product. The shape has the following properties:
Name The name of the Windows Application
Use Registry Value for Application Name If you have multiple installations of your application, this setting will ensure that each application is monitored separately, based on a registry value. For each unique value found in a registry key, a unique instance will be created.
This shape is used to create groups of computers in Operations Manager based on criteria you specify. You can attach monitors to a Server Computer Group, just like a Server Role or Server Component. The Computer Group can be used standalone; it can also be attached to a Roll-up Container or Windows Application shape. The shape has the following properties:
Name The name of the Server Computer Group
Monitoring Shapes
The monitoring shapes represent the monitors that gather data from the components of your application, and either raise an alert or record that data to the Operations Manager database, or both. Each monitoring shape needs to be attached to a modeling shape to be effective. A single modeling shape can have several monitoring shapes attached to it, of varying types, but a a monitoring shape can only be attached to one modeling shape. There are five different types of monitoring shapes; which one you use depends on what aspect of the component you want to monitor.
Windows Performance Counter Monitor shape
The purpose of the Windows Performance Counter Monitor is to track the value of a Windows Performance Counter on your application. You can record the value of the counter to the database at intervals, so that you can track performance over time and possibly report on it later. You can also configure the monitor to generate an alert if the counter exceeds a certain value, either once, or multiple times over a set period, or on average. This shape cannot be used standalone, because then it would have nothing to monitor; it must be attached to a Server Role or Server Component or Server Computer Group. This shape has the following properties
Name The name of the Performance Counter Monitor
Object The Performance Monitor object to monitor. For more information about Performance Monitor, see Using Performance Monitor.
Counter The Performance Monitor Counter to monitor
All Instances A single component may have multiple instances of a counter (for example, a server with multiple logical disks would have multiple % idle time counters). This setting indicates whether the monitor should monitor all instances of the perf counter. Valid values are TRUE and FALSE.
Instance If All Instances is set to FALSE, indicate the specific instance to monitor here. If All Instances is set to TRUE, this field will not appear.
Alerting Behavior This field defines what the monitor does with the data it collects. There are three possible values, and the value you choose will affect what configuration options are displayed:
  • Alert – The monitor may generate an alert based on the collected data. Choosing this option makes the alert configuration options available.
  • Alert and Collect – The monitor may generate an alert based on the collected data, and also records the data to the Operations Manager Data Warehouse. Choosing this option makes both the alert and collection configuration options available.
  • Collect – The monitor will record the data to the Operations Manager Data Warehouse, but will not generate alerts. Choosing this option makes only the collection configuration options available.
Comparison Type (Alert configuration) Indicates how the counter must exceed the threshold in order to generate an alert. All the possible values for this setting use the same configuration options. There are three possible values:
  • Consecutive – The alert is generated only after the counter exceeds the threshold for a specified number of consecutive samples. This helps to eliminate false alerts caused by short-term spikes in the data. If you want to generate an alert every time the threshold is exceeded, use this setting with a sample size of 1.
  • Average – The alert is generated if the average value of the counter over a number of consecutive samples exceeds the threshold. This also helps to eliminate false alerts.
  • Delta – The alert is generated if the difference between the current sample and the previous sample exceeds the threshold for consecutive samples. This lets you determine if the value of the counter is rising or falling rapidly.
Interval (Alert configuration) Indicates how often to sample the counter, in seconds
Number of samples (Alert configuration) Indicates how many consecutive samples to compare. What kind of comparison happens with the samples depends on the comparison type you chose.
Threshold (Alert configuration) The threshold that you're comparing the sample value to. What value you choose here depends on the counter, and the particular monitoring needs of your system.
Operator (Alert configuration) Indicates how to compare the sample to the threshold. The only possible values here are greater or less. There is no "equal to" option.
Collection Interval (Collection configuration) Indicates how often the performance counter is collected, in seconds
Create Performance View (Collection configuration) Indicates whether a performance view is created to display the data collected by this counter.
Create Report (Collection configuration) Indicates whether a report is created to display the data collected by this counter.
Report Name If Create Report is set to TRUE, this setting indicates the name for the report the customer should see in the Operations Console. If you want to show multiple performance counters in the same report, you can specify the same report name for each monitor.
Advanced Alert Settings (Alert configuration) Indicates whether to show the following advanced alert settings:
  • Alert Priority – The alert priority when the alert is generated in the Operating Console. Possible values are High, Medium, and Low.
  • Alert Severity – The alert severity when the alert is generated in the Operating Console. Possible values are Critical, Warning, and Information.
  • Alert Description – The alert description seen by the user in the Operating Console. You can and should customize this message by editing it. You can include the name of the object, counter, and instance by using the following keywords surrounded by brackets: #Object#, #Counter#, #Instance#, and #Value#.
Health Category Indicates the category that this monitor should affect in the operations console. Valid options are Availability, Performance, Configuration, and Security.
Windows Event Monitor shape
The Windows Event Monitor monitors Windows event logs for specified events. You can configure the event monitor to either collect the events or generate an alert in response to the event. You will need to know something about the event log you want to monitor and the events that can be logged in order to configure this monitor correctly. This shape cannot be used standalone; it must be attached to a Server Role or Server Component or Server Computer Group.
Note: It isn't possible to monitor the absence of an event. For example, you might want an alert to be raised if a "server connection" event isn't received within 10 minutes. For that type of configuration, you need to use another authoring tool.
Name The name of the Windows Event Monitor
Log Name The name of the event log that the monitor is watching for the event
Red Event ID The event ID that causes the monitor to generate an alert. You will need to provide this information based on your familiarity with the event log being watched.
Red Event Source The event source of the red event. Again, you will need some knowledge of the event log to provide this information.
  • Alert and Collect – The monitor may generate an alert based on the collected data, and also records the data to the Operations Manager Data Warehouse. Choosing this option makes the alert configuration options available; there are no collection configuration options.
  • Collect – The monitor will record the data to the Operations Manager Data Warehouse, but will not generate alerts. Choosing this option removes the alert configuration options; there are no collection configuration options.
Auto Reset Indicates the condition that causes the monitor to reset to a healthy state. There are three possible values for this setting:
  • Timer – The monitor resets automatically after a specified amount of time. This option has one setting:
    • Auto Reset Interval – The amount of time (in seconds) after which to reset the monitor.
  • Manual Reset – The user must reset the monitor manually.
  • Green Event – The monitor resets after a specified "green event" occurs. This event can be in the same log as the "red event" that generated the alert, or a different one. There are two settings:
    • Green Event ID – The event ID that causes the monitor to reset.
    • Green Event Source – The event source of the green event.
Repeats N times. N= For certain events, you may not want to generate an alert unless the event is repeated multiple times. This setting allows you to specify how many times the event needs to occur before the alert is generated. The default is 1, which you should keep if you want to generate an alert every time the event occurs.If you select a value greater than 1, then you will be prompted to specify a number of seconds that the events must occur within.
  • Alert Description – The alert description seen by the user in the Operating Console. You can and should customize this message by editing it. You can include the event description by using the following keyword surrounded by brackets: #EventDescription#.
Windows Service Monitor shape
This shape is used to monitor a Windows Service. This monitor can only monitor processor usage or memory usage, and issues an alert if either passes the threshold. This shape cannot be used standalone; it must be attached to a Server Role or Server Component or Server Computer Group. The shape has the following properties:
Name The name of the Windows Service Monitor
Service Name The name of the Windows service to monitor. This is the name in Service Manager, not the display name.
Monitor Auto Started Services Only Indicates that the service will only be monitored it is configured to start automatically. This is to prevent a service from being monitored when it has been disabled or should not always be running.
Monitor CPU utilization Can be set to TRUE or FALSE. Indicates whether you're monitoring and alerting on CPU utilization of the service. If this is set to TRUE, there are three additional settings:
  • CPU Threshold Percentage – The threshold percentage of CPU utilization at which the monitor will generate an alert.
  • CPU Sample Repeat Count – The number of consecutive samples above the threshold after which the monitor will generate an alert.
  • Collect CPU usage – If TRUE, the monitor will collect CPU usage for the service and write it to the data warehouse.
Monitor Memory Utilization Can be set to TRUE or FALSE. Indicates whether you're monitoring and alerting on memory utilization of the service. If this is set to TRUE, there are three additional settings:
  • Memory Threshold – The threshold percentage of memory utilization at which the monitor will generate an alert.
  • Memory Sample Repeat Count – The number of consecutive samples above the threshold after which the monitor will generate an alert.
  • Collect Memory usage – If TRUE, the monitor will collect memory usage for the service and write it to the data warehouse.
Sample Rate The frequency, in seconds, at which the monitor should take a sample.
  • Alert Description – The alert description seen by the user in the Operating Console. You can and should customize this message by editing it. You can include the event description by using the following keywords surrounded by brackets: #service#, #computer#.
Web Site Monitor shape
This shape is used to monitor the health of a URL via a simple ping; it doesn't do anything else. This shape cannot be used standalone; it must be attached to a Server Role or Server Component or Server Computer Group. The shape has the following properties:
Name The name of the Web Service Monitor
URL The URL to monitor
  • Alert and Collect – The monitor may generate an alert based on the collected data, and also records the data to the Operations Manager Data Warehouse. Choosing this option makes the alert configuration and the collection configuration option available.
  • Collect – The monitor will record the data to the Operations Manager Data Warehouse, but will not generate alerts. Choosing this option makes the collection configuration option available.
Interval (Alert Configuration) How often to ping the URL, in seconds.
Response Time Threshold (Alert Configuration) How long monitor will wait for a response before generating an alert.
Create Performance View (Collection Configuration) Creates a performance view tracking the response time of the URL.
  • Alert Description – The alert description seen by the user in the Operating Console. You can and should customize this message by editing it. You can include the event description by using the following keywords surrounded by brackets: #Computer#, #URL#.
Database Monitor shape
This shape is used to monitor a database via an OLE DB query. All it does is determine whether the database is responsive or not, and optionally collect the time that the database took to respond. This shape cannot be used standalone; it must be attached to a Server Role or Server Component or Server Computer Group. The shape has the following properties:
Name The name of the Database Monitor
Connection String The connection string to use
  • Alert and Collect – The monitor may generate an alert based on the collected data, and also records the data to the Operations Manager Data Warehouse. Choosing this option makes the alert configuration options and the collection configuration option available.
Interval (Alert Configuration) How often to run the query, in seconds.
Create Performance View (Collection Configuration) Creates a performance view tracking the response time of the database.
  • Alert Description – The alert description seen by the user in the Operating Console. You can and should customize this message by editing it. You can include the event description by using the following keywords surrounded by brackets: #Computer#, #Connection#.
Connection Shapes
The connection shapes are shapes that associate one shape with another. That could be monitors associated with a server component or server role, or multiple components rolling up to a single container that represents their overall health. There are only two types of connection shape, which are found on the MP Roll-up tab.
Health Roll-up
This shape is used roll up the health of a server role or server component to another object. This aggregates the health state of the distributed server roles or components into a single entity for easier monitoring. This shape has the following properties:
Roll-up This property indicates the aspect of health that you're rolling up. The options are Availability, Configuration, Performance, Security, and All.
Aggregation Method There are two options for this property: Best of and Worst of. Worst of is the default, and the most often used. This setting indicates that the aggregate health for the components being rolled up is represented by the least healthy member. That is, if you're monitoring server availability among several distributed servers, and just one of them is offline, the roll-up container will show as unhealthy. If the property is set to Best of, a single healthy component is all that's needed for the roll-up to be healthy.
Monitor Connector
This shape is used to connect a monitor to the shape that it's monitoring. It has no properties to set.
